vortech z overheating help!!!
Old Jun 23, 2013 | 02:29 PM
35thsickz33's Avatar
35thsickz33
Default vortech z overheating help!!!
alright I got a vortech z its been running slightly hot some times !!! I was at idle for about 10min and the temp starting rising high about 3/4 of the way then I turned it off waited 10min then drove back to regular temp and then again when I stopped to put in gas then turned it back on . Its only does this while im parked or its off and I turn it back on right away !!! but as soon as I start driving it goes back to normal temp . any suggestion I ready checked for air bubbles not that ,the heat has been rising around here though around 100-106 im thinking maybe a vented hood will help I check both fans also they working .
Old Jun 23, 2013 | 04:08 PM
suprasam's Avatar
suprasam
Any chance your tstat is malfunctioning? But then again no outside air is flowing over the radiator while you're sitting but it should not get that hot.
Old Jun 23, 2013 | 04:10 PM
mattleegee's Avatar
mattleegee
rebleed or tstat
Old Jun 23, 2013 | 04:33 PM
P&K350Z's Avatar
P&K350Z
Do you have an aftermarket radiator?
Old Jun 24, 2013 | 01:27 PM
binder's Avatar
binder
Needs rebled. Use a spill free funnel so the coolant fill will be above the heads. Air gets trapped behind the thermostat keeping it from opening fully.
You don't need a vented hood or anything as a stock functioning system will cool that car with no problems. People in 120*+ over in dubai have no issues. I was boosted to 600hp for 2 years on the stock system and drove it in triple digit heat.
Old Jun 24, 2013 | 04:54 PM
Zivman's Avatar
Zivman
check to make sure your fans are coming on.
Old Jun 25, 2013 | 05:36 AM
35thsickz33
stock radiator ,both fans do come on checked that , didn't have problems last year could bubbles come up now ?? also my temp guage for the outside will read like 10degree's over then come back down then go slowly back up .. if Its the t-stat should I stick with oem or go with mishimoto or nismo ??
Old Jun 25, 2013 | 06:09 AM
terrasmak's Avatar
I don't know of one FI Z in Vegas (other than Stillen SC) that doesn't have over heating issues.
Old Jun 25, 2013 | 10:30 AM
tcode's Avatar
tcode
You might want to replace radiator cap too. I had same overheating issues, bleeding coolant system, was good a couple of days then overheated again. Till I replaced radiator cap. Bleed system one more time and after that never had overheat issues again. Seals on radiator cap went south and radiator when cooled, instead of vacuum coolant from relief reservoir, suck air through bad seals.
Old Jun 25, 2013 | 04:53 PM
binder's Avatar
binder
Well vegas is a lot cooler than dubai so I'm not sure what those guys are doing then.
Rad cap being bad wouldn't provide enough pressure on the cooling system which in turn would allow the coolant to boil over sooner than if it had proper pressure. Stock pressure cap will work just fine and they are under 5$ replacement at the parts store.
350Z_Al
Oct 29, 2020 07:44 PM
seagrasser
Oct 11, 2015 03:27 PM
bneumann
Oct 7, 2015 12:16 PM
Calinismo350z
Sep 14, 2015 04:04 PM
