Stillen Supercharger Installed!!!!!
Old Feb 16, 2004 | 11:38 PM
  #41
chaparro78's Avatar
chaparro78
Default Re: final
Originally posted by m3powerrr
final
Very sweet set-up - can you run down what every gauge does?
Old Feb 17, 2004 | 12:24 AM
  #42
myinfinitig20's Avatar
myinfinitig20
lets see some 1/4 times...
Old Feb 17, 2004 | 03:36 AM
  #43
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
I can't imagine that your engine is covered by any warranty from Stillen. Especially if you installed it yourself! Why would Stillen cover a blown engine if the installer made a mistake?
Old Feb 17, 2004 | 04:43 AM
  #44
FLY BY Z's Avatar
FLY BY Z
Bonz, when they take it apart, they will be able to tell what caused the problem.
Old Feb 17, 2004 | 08:33 AM
  #45
m3powerrr's Avatar
m3powerrr
Dude, the track isn't even open yet.
Old Feb 17, 2004 | 08:47 AM
  #46
m3powerrr's Avatar
m3powerrr
I read the warrenty. It means nothing. If anyone's ever worked on their car or modded their engine, you have to be very ignorant to warrenty that job, espicially when it comes to boosting applications. Every high horsepower car out there needs a rebuilt motor at shorter intervals. There really is no way to get the power you want without risking your motor. It just wasn't designed to do that. Whenever an engineer designs a product, the margin of safty is usually 2 to 2.5. Sometimes much higher. If you start modding that car and decrease the margin of safety, physics/numbers will tell you that you've increased the risk. I've delt with these aftermarket companies who claim to have warrenties. It's just a gimmick. Another way to sucker you in to paying an extra 2 - 3 hundred dollars. It means nothing.
Bottom line: More power does not equal Reliability!
And please, don't post no **** like "I did such and such to my car and it lasted me 200 years already!"
I'm making a general statement. There's always exceptions.
Old Feb 17, 2004 | 09:14 PM
  #47
chaparro78's Avatar
chaparro78
What is the run down of your gauges? What each one does?
Old Feb 18, 2004 | 01:45 AM
  #48
I-Speed GC8's Avatar
I-Speed GC8
It appears to be volts, oil pressure and air temp? Nice job on the gauges given attention to detail and precision. Nice combination of gauges as well EGT, A/F, Boost, and oil pressure very important when you have modifications of this level done to a NA car. Nice job!
Andy
www.i-speedusa.com
Old Feb 20, 2004 | 04:04 PM
  #49
StillenScott's Avatar
StillenScott
Default Re: final
Did you used to pilot an M3? And what are the differences you have experienced between the Z and the M?
Old Feb 21, 2004 | 08:48 PM
  #50
m3powerrr's Avatar
m3powerrr
Default Intercooler
Here's some intercooler pictures.
  #51
m3powerrr's Avatar
m3powerrr
Default intercooler2
Intercooler2
Old Feb 21, 2004 | 08:50 PM
  #52
m3powerrr's Avatar
m3powerrr
Default Intercooler3
Incooler3
Old Feb 21, 2004 | 08:51 PM
  #53
m3powerrr's Avatar
m3powerrr
Default Incooler4
Intercooler4
Old Feb 23, 2004 | 07:34 AM
  #54
ColecatZ's Avatar
ColecatZ
Cool, Stillen isn't the prettiest kit by far.......but I like it.
Thanks for sharing.
Old Feb 23, 2004 | 07:49 AM
  #55
teh215's Avatar
teh215
One of the main reasons that I visually dislike the Stillen intercooler is the black hoses that just seem to be laying in the engine compartment. Is there a better way to route the hoses. Also, would it be possible to use braided line with AN fittings to connect to the IC and the intake?
Old Feb 23, 2004 | 09:35 AM
  #56
m3powerrr's Avatar
m3powerrr
We will be doing that braided line soon.
Old Feb 23, 2004 | 10:40 AM
  #57
daking350's Avatar
daking350
How does that intercooler work??I am not familiar with the function of an Air to water intercooler..
Old Feb 23, 2004 | 10:48 AM
  #58
m3powerrr's Avatar
m3powerrr
There are 2 heat exchangers and a water pump. One heat exchanger in front of the car and the other one is under the upper plenum. Water pumps through the front heat exchanger and cool water circulates through the heat exchanger under the upper plenum. When the air passes through it, it exchanges heat and the hot water is carried to the front of the car to get cooled again.
Old Feb 23, 2004 | 11:35 AM
  #59
TXREFI's Avatar
TXREFI
Default Air to air better?
Wouldnt that limit the cooling to the temperature of the water? Since air flowing in from the front could be 50 to worse case in Texas 100 degrees outside, wouldnt a air to air be more effective?
I doubt the water ever gets any cooler than 100 after the car is running.
Old Feb 23, 2004 | 01:59 PM
  #60
m3powerrr's Avatar
m3powerrr
You are not using the water from the engine. It's a different water storage.
