Adjustable cam gears
Old Sep 6, 2013 | 06:29 PM
meatbag's Avatar
meatbag
Default Adjustable cam gears
Anyone interested in adjustable cam gears that ditch the VVT systems all together?
This would mainly benefit people trying to make big power(degreeing cams), people doing swaps, and people that like to experiment. They would have 10deg -+ of cam adjustment. The intake ones are drawn up in cad and the exhaust ones are still being worked on at the moment. You would need a stock set of cam gears as a core.
Old Sep 6, 2013 | 09:49 PM
midz350's Avatar
midz350
I think Fontana Nissan did this to their 500HP N/A 350z.
People should have done this years ago.
The VVT never works as intended, OEM or with aftermarket EMS's.
Old Sep 7, 2013 | 04:58 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
would they be adjusted by just removing the small cam covers?
Old Sep 7, 2013 | 05:45 AM
rcdash's Avatar
rcdash
Without the ability to control during the rev range, the power band narrows though, correct? I'm not sure how VVT never worked out when it does fatten the torque curve...
Old Sep 7, 2013 | 08:03 AM
meatbag's Avatar
meatbag
You will loose power somewhere you cant have it all but you could tune the cams specifically for what you are doing.
Yes you would need a revup front timing cover so you could access both cam gears for adjustment.
Old Sep 7, 2013 | 08:39 AM
midz350's Avatar
midz350
The VVt is causing a lot of problems to the HR guys. It happened to me (engine sputtering and losing power) and I remember some guys had problems with it in the Haltech thread.
sherm
Apr 11, 2020 05:21 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
RyansZ33
Sep 15, 2015 05:54 AM
