Supercharger Dyno Numbers
Old 05-02-2017, 10:10 PM
  #141
OldManZ350
OldManZ350's Avatar
That's not an Air Filter, it's a Rock Catcher....
It's no good for the street, but fine for the race track.
Originally Posted by BluestreamDE
I have the Original mesh design. Should not be an issue with the MAXX or Chrome style. Since you have a Ysi I would suggest the MAXX anyway since you could pull in the mesh and damage your impeller if the screen came loose.
Old 05-03-2017, 06:50 AM
  #142
350z006
350z006's Avatar
Agreed...I was thinking about incorporating it with a velocity stack, but purely for track use...
Old 05-03-2017, 07:38 AM
  #143
0taku
0taku's Avatar
You are NOT Choking at 10psi, something else is going on.
Also, no way you're making 500whp with only 10psi
Post your Boost Log.
What are the Detail of your Build?
https://my350z.com/forum/forced-indu...ttlenecks.html
The only boost I can go off is the boost gauge itself unless the AEM unit isn't reading correctly at the manifold.
Old 05-05-2017, 12:45 PM
  #144
philthethrill
philthethrill's Avatar
Finished up drivability today, they couldnt do a final pull with filter off since my green vwlt was slipping. I cant believe it .i mean i believe it but thats crazy. They spoke with gates and ordered me a spwcial racing belt. Late nwxt week lookin for final numbers.
Old 05-05-2017, 01:10 PM
  #145
OldManZ350
OldManZ350's Avatar
Just tighten up the belt 1/4 turn at a time.
Maybe you ran out of adjustment?
There is no a Gates Racing Belt available in those length.
Old 05-05-2017, 01:32 PM
  #146
philthethrill
Its a 92. Something going to shoe horn it on. And the belt was tightened all the way. Im thinking they may have got me to large of a belt to begin with . Idk im somewhat unser because of the crank pulley i just put on. Either way this one is wat smaller. They spoke with gates directly,gates also said use this belt over the green one. Wich i know the king of mustang vortechs and all tbey use is green belts with success. So,i guess they just bought to big of one
OldManZ350 (05-05-2017)
Old 05-05-2017, 08:27 PM
  #147
BluestreamDE
BluestreamDE's Avatar
What do you all mean by a "Green Special Racing belt"? I never heard of this. Is this a specific brand? Is it better than the off the shelf belts gates sells?
Old 05-06-2017, 03:23 AM
  #148
2bad240
2bad240's Avatar
The gates green back HD belt is what they are talking about. and as far as the gates racing they just came out with a new line of racing belts and right now the sizes kinda hard to find but I have one on mine and it's the best belt I have ran.
BluestreamDE (05-08-2017)
Old 05-08-2017, 08:23 AM
  #149
350z006
350z006's Avatar
Are they the blues?
Old 05-08-2017, 11:26 AM
  #150
2bad240
2bad240's Avatar
No they are black and a little thicker
Originally Posted by 350z006
Are they the blues?
Old 05-08-2017, 08:52 PM
  #151
philthethrill
Yep thats what i got on the way
Old 05-08-2017, 11:27 PM
  #152
BluestreamDE
Thanks 2bad240, I'll look into buying this for my Z as well.
Old 05-13-2017, 04:39 PM
  #153
philthethrill
Well looks like overspinning a v2 ti isnt a good idea. Getting a intermittent squeaking noise from the jack shaft. Havent even put 1 street mile on it yet and i see a bearing replacement in my future. Those twin turbos sound better every day
Old 05-13-2017, 06:12 PM
  #154
Logiqal
Logiqal's Avatar
^How fast did you spin it? I would of expected that trim to take a little abuse with its HD bearings.
Old 05-13-2017, 07:09 PM
  #155
philthethrill
I don't know the exact off the top of my head but i think its in the low 70s. Im not 100 percent there busted . Tuner just told me the jack shaft was squeaking on and off. Could be dirty bearings but... who knows. Ill find out when i get it back i guess.
Old 05-13-2017, 07:33 PM
  #156
2bad240
2bad240's Avatar
jackshaft is not the blower. That's part of the bracket
Old 05-14-2017, 04:38 PM
  #157
philthethrill
What im saying is the jack shaft is being over spun
Old 05-14-2017, 05:24 PM
  #158
2bad240
2bad240's Avatar
Check the backside of the pulleys and make sure they are not rubbing
Old 05-15-2017, 07:18 AM
  #159
philthethrill
No additional power was made with the filter off, car is makimg high570s low 580s constantly but the jacksahft is getting louder and louder. Im getting it towed home and replacing bearings myswlf si ce i cant afford anymore 130.00 hpur rate. New belt is great btw no slip
Old 05-15-2017, 10:55 AM
  #160
350z006
350z006's Avatar
is it a k060935rpm belt?
Quick Reply: Supercharger Dyno Numbers
