vq35de rebuilt what can i do oil preston flow
Old Feb 11, 2014 | 04:47 AM
vqpower 2's Avatar
vqpower 2
Talking vq35de rebuilt what can i do oil preston flow
Hi every one
first i'm french Canadien so that why my english is not realy good
i search to find what can i do inside my vq35de rebuilt to get better internal flow because my engine never last more then one summer
My setup
rebuilt oem crank whit acl race bearing ( oem size )
brien crower rod
cosworth 8.1 piston
arp stud
rebuilt head stock
metal head gasket
pathfinder cooling kit
greddy oil pan
turbonetic single turbo kit whit garett gt35 turbo
run at 8-9 psi last summer
tanabe exhaust
my bad is i did not go to the dyno last year because my engine & turbo cost me to much ( this year i will go to dyno looking to boost around 16 psi if i have 400 whp i m happy i want durable good setup )
when i drift my engine over heat so i buy a koyo rad and i m looking to buy a oil cooler
what happen is when i was around 160 mph my crank bearing crush and partially destroyed i use syntetic Gulf oil
what i m looking is there any way i can upgrade the oil and prestone flow inside my engine
because my vq is a part right now and i have time to do porting or ?
thanks guy for your answer hope that will help me do a better setup !!
Old Feb 11, 2014 | 05:24 AM
djamps's Avatar
djamps
you should be using a new revup oil pump for each build. also consider looser clearances if you are tracking it.
Old Feb 11, 2014 | 05:25 AM
dkmura's Avatar
dkmura
General & DIY Moderator
It took me awhile to read through your post and determine what you're really asking. If you are looking for ways to increase internal coolant flow, there really isn't any. Porting is a term generally reserved for refining airflow through the heads, not coolant through the block. You mentioned not using an oil cooler on your boosted VQ and that really is the biggest external change you can make to keep oil temps down.
If you have the engine apart right now, and it severely overheated last summer, you'd be well-advised to have all the internal components tested and checked. For example, the crank should be magnafluxed and checked for straightness. The block crack checked as well, before those pricey rods go back in. As for oil recommendations, you should really read Resolute's UOA thread for some solid data points to consider.
Old Feb 11, 2014 | 05:48 AM
dkmura's Avatar
dkmura
Good points- and he's talking about slightly bigger BEARING clearances to provide better cooling. It's an old racing trick, and it works, but don't expect long life out of it.
Old Feb 11, 2014 | 09:31 AM
vqpower 2's Avatar
vqpower 2
ok thx guys like i said my english suck lol
i know porting is for head
but i didn know how to say what i want
i want to know if i can oversize some oil pass or preston pass so thx dkmura for your answer
i know coswort have bigger oil pump but is realy expansive
i didn know about the rev up oil pump thx i will do that
i read about put a rev up intake for the air flow i have one in hand so i may try that what you guys think about that
and it s full shure everything will be check by my friend tuner shop before i do my rebuilt
and this z is my daily weekend track car so i don t know if i should do looser clearence
Old Feb 11, 2014 | 05:07 PM
DaveJackson's Avatar
DaveJackson
Master
Bigger, faster fan with higher cfm (cubic feet of air per minute).
Switch to a coolant mixture higher in water concentration because water has a higher specific heat capacity.
Old Feb 11, 2014 | 05:40 PM
taywan's Avatar
taywan
Seems like a good tune before beating on it would be a great idea like you say. And jeez you should be way a over 400whp at 16psi when 8psi TN does 380-400. Or Ami missing something??
lapham3
Oct 7, 2022 03:15 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
