Greddy TT blow off valve question
Old Feb 3, 2004 | 05:20 AM
g356gear's Avatar
g356gear
Default Greddy TT blow off valve question
There seems to be some debate in my reading about what is the best blow-off valve for the MAF equipped turbo kits. I want to add a BOV to the Greddy TT kit but I was looking for input on placement on the intake tube and what brand seems to work the best for response and daily driving. I have been looking at the Greddy Type-S, HKS, and Blitz models. Any others?
Old Feb 3, 2004 | 09:15 AM
Drag Limited's Avatar
Drag Limited
I am caught totally off guard that it does not have a bov?!?! ARE YOU SURE?
Old Feb 3, 2004 | 09:23 AM
g356gear's Avatar
g356gear
Apparently Greddy says the kit does not need one but I wanted to put one on for a little extra safety.
Old Feb 3, 2004 | 09:29 AM
Drag Limited
oh?!? well I am running HKS SSQV and I LOVE IT!!! I suggest you go with that and recirculate it!
Old Feb 3, 2004 | 09:56 AM
g356gear's Avatar
g356gear
What is the importance of recirculation with the BOV? I have seen quite a few that vent direct to the outside.
Old Feb 3, 2004 | 12:19 PM
etx's Avatar
etx
Put the bov before the MAF and your good to go. The ecu is not going to spray fuel for air that the sensor never sees.
Old Feb 3, 2004 | 12:41 PM
Drag Limited
greddy TT puts the maf in the intercooler pipes!?! wow I am learning all kindza stuff about the kit I did not know.
Old Feb 3, 2004 | 01:56 PM
g356gear's Avatar
g356gear
Where else could it be but on the intake pipe from the intercooler up to the throttle body? That's where it is in stock form.
Old Feb 3, 2004 | 02:59 PM
Drag Limited
hahahaha stock form? Ok the engine is NA in stock form so thats a joke to say its placed in the IC pipes stock. The earlier Z TT's had the MAFS before the turbo (just like all other stock MAFS turbo cars) My SR20DET has the MAFS BEFORE the turbo, friends EVO, Talon, Mx6, and MR2 also have this configuration. That is why when the factory BOV recirculates it goes in after the MAFS but before the turbo(on SR engines anyways) The problem with MAFS being placed in the IC pipes is the pipes cannot change diamater otherwize it could throw calculation off(of so I have been told). The good thing with putting it in the (cold pipe as us SR guys have come to call it) is that you can blow off atmospherically with out running rich thus resulting in our discussion. I was impressed that greddy opted to do that especially when not running a BOV with the kit.
Cliffnotes : factory cars run the MAFS on pre turbo non pressurized pipe.
Old Feb 4, 2004 | 05:57 AM
g356gear's Avatar
g356gear
To clarify.....there is very little room to put the BOV on the greddy tt kit in any other location than in the driver front lower corner....closest possible to the throttle body. And when I say that's where the MAF is in stock form....that is where it is ...the MAF is about 18" before the throttle body in NA form. This is where the MAF stays for the Greddy kit....for simplicity and no unecessary hacking of the wiring harness.
Old Feb 4, 2004 | 10:34 AM
Drag Limited
oh ok gotcha thanks for clearing that up you meant physical location not in reference to pipes. Gotcha
sales@czp
Sep 23, 2019 03:30 PM
