What compression on psi should i have whit 8-1 piston
Old May 21, 2014 | 03:09 PM
vqpower 2's Avatar
vqpower 2
Default What compression on psi should i have whit 8-1 piston
Ok last weekend i been at the track and my vacum hose break so my turbo boost way to much Now my engine smoke oil when i hit the gaz i ve Check the turbo is ok
Now i Check the compression i have 85 psi on 2 front cylinder and 95 - 100 to the others i have 8-1 cosworth piston is it normal i think its Low but i m not shure
Thanks for help me out
I Know my english suck im french lol
Old May 21, 2014 | 03:14 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
read the pressure at home, uncorrected so PSIa, multiply by 8 and that is what you should get max...depending on losses in rings/valves.
is home a high altitude location?
Old May 21, 2014 | 03:23 PM
vqpower 2's Avatar
vqpower 2
I Forget to say my engine was rebuilt 2 week ago
I live in Québec Canada its not high altitude here and i ve Check the pressure at home after running the engine 5 min whit out turbo my friend Mecanic think its the seal valve leaking What you guys think
Old May 21, 2014 | 03:24 PM
vqpower 2's Avatar
vqpower 2
Seal valve leak inf. For the oil smoke not for compression lol
apex locator
Jul 23, 2021 02:27 AM
B Esquire
Sep 24, 2015 07:52 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
