Powerlab upgrades
Old Dec 5, 2014 | 09:28 AM
str8dum1's Avatar
str8dum1
you are no where near maxing the injectors at 500whp on E85. Why are you running 60psi base? That makes no sense. Back off to 43psi and I bet you have way more injector duty.
Originally Posted by R6n350GT
I am in a similar situation.
weisco 8.8:1 pistons, E85, 35R turbo, not sure if .82 or 1.0 rear, T3, 1000cc Dw injectors, stage 3 CJM kit, 500HP and tuner says injectors are maxed out...60psi base pressure, 80psi full boost. HKS external wastegate at 14psi, 3" exhaust fujitsuo.
Do i get the Blackops / FID stainless Bosch IV14 1200cc or 1400cc injectors and push more fuel at it? Tuner also said before i changed wastegate vac lines that back pressure was an issue but i changed according to this.
http://www.turbosmart.com.au/wp-cont...Y_12_rev_2.pdf
from Two port connection Method (2) (For obtaining maximum boost pressure on your turbo system)
to Two port connection Method (1) (For controlling boost on a turbo system with high back pressure)
as was getting boost spike...
any suggestions on injector size and other tips? OP hope the pdf helps you out on the back pressure.. i only got a 460 to 500Hp using 98 pump from pump to e85 ..
Old Dec 10, 2014 | 06:08 PM
rcdash's Avatar
rcdash
More base fuel pressure will allow injectors to flow more. You will be pump limited at the upper end. I agree there should be more left in a 1000cc injector at 500 whp (DJ). At 80 psi the fuel pump may be the weak link. Getting 1300cc injectors (recommend ID), you can lower the base fuel pressure and let the pumps work better.
Old Dec 10, 2014 | 08:29 PM
james12345pt's Avatar
james12345pt
I am going next week to pick up my new dual 3 inch exhaust and play with adding some extra meth to the tune to see what kind of numbers that I can put down. If this does achieve 600whp than I will have some 1300cc injectors installed and have the car tuned for e85. Per my tuners suggestion, I add an 1/2 plenum spacer to help intake air flow. He state that he improved boost effectiveness by using this mod on turbo cars.
Old Dec 11, 2014 | 09:28 PM
IIQuickSilverII's Avatar
IIQuickSilverII
Originally Posted by james12345pt
By the look of things, I don't think a t4 flange will fit without some major mods or losing the ac. How about a 6766 with the 3 inch vband inlets? Is the back pressure stopping the turbo from making power pass 16 psi or is it the turbo itself. If it is the high backpressure, would running a dual three inch exhaust help?
It can be done, ac works... Precision T4 76mm..3.5" dp 4" exhaust
Something else else you can try other than exhaust too and being cost efficient, look at the SoundPerformance's cutout
http://www.spracingonline.com/spblog/?p=114
Not sure if its been mentioned, but teflon(PTFE) fuel lines are recommended...generally...good luck!
Btw, hello Raj and Rich
Old Dec 12, 2014 | 02:57 AM
james12345pt
I have an stage 1 cjm fuel system and am going to upgrade the fuel pump. I will check into the cutout today. Thanks
Old Dec 12, 2014 | 03:03 AM
james12345pt
Also, My current exhaust was piecemeal together with an powerlab pipe, homemade reversed y and a cheap ebay exhaust. I am looking forward to an better sounding exhaust with better flow but without so much rasp. I am looking at an open dump from the wastegate to free up some flow as well.
Old Dec 14, 2014 | 02:14 AM
Resmarted's Avatar
Resmarted
Originally Posted by str8dum1
just run e85, take wastegate line off and lay on the timing.
that will get you 600whp
I think I'm going to make this my signature
dcains
Nov 11, 2015 11:36 PM
