vq35hr vs vq37
Old Jan 13, 2015 | 10:03 PM
racer59's Avatar
racer59
Default vq35hr vs vq37
Hi looking at fitting a vq37 crank into a hr block are the blocks the same deck height?, I no I need different rods etc I already have a spare hr block looking at 37 rods they seem to be longer than the 35.
Any help will be great.
Old Jan 14, 2015 | 04:23 AM
suprasam's Avatar
suprasam
CHeck out this thread
https://my350z.com/forum/forced-indu...ct-hitomi.html
Old Jan 14, 2015 | 10:21 PM
Juztin's Avatar
Juztin
It's drop in when you use the right pistons and rods combo - IIRC VQ37VHR rods w/ VQ35HR pistons. Read this thread which is specified in the thread suprasm pointed you too for the goods: https://my350z.com/forum/vq35hr/4716...l#post10048222
Old Jan 14, 2015 | 11:26 PM
racer59's Avatar
racer59
Thanks for info just making sure don't wish to buy all the the parts and find out the deck heights are diff
Old Jan 15, 2015 | 04:40 AM
tommy smith's Avatar
tommy smith
Default I just don't get it
Since you already have an HR, why take risks, spend money and time to do this??? There's much more difference between the Nissan 3.5 & 3.7 engines than just that little size difference.
What if after you do ALL that & get lucky by not having major issues, what if that 3.7 doesn't produce more power but less.
Old Jan 15, 2015 | 11:13 AM
phunk2's Avatar
phunk2
HR and VHR are supposed to have the same deck height. You would take the VHR crank and rod length. You will want to use HR style pistons because VHR pistons do not have the exhaust cam valve reliefs since the VHR heads have static exhaust cams.
Forged HR pistons look the same on the top, but the L/R bank pistons are different in how they are clearanced for the oil squirter. Pay attention to that when assembling so you dont have to do it again when a squirter breaks off on first crank of the motor.
Old Jan 14, 2016 | 07:01 PM
venture210's Avatar
venture210
Here's the post to set everything straight.
Use a vq37 crankshaft and vq37 rods with vq35hr pistons.
Why?
vq37vhr stroke is exactly 4.6mm more than the vq35hr.
vq37vhr rod length (center to center) is 2.286mm shorter than the vq35hr
At TDC the vq37 crank will put the vq35hr piston 2.3mm higher than it should be. Using a vq37 rod in place of the vq35hr rod, the piston will be pulled back down by 2.286mm. That means the piston will be a mere 0.014mm higher than it should be. For those worried about clearances, keep in mind that oil clearance between the rod and crank alone will push the piston down more than enough to be safe. Account for head gasket thickness and you're now golden. An additional note to add is to make sure the pistons have a small notch or relief on the skirt to clear the oil squirters (info courtesy of Juztin)
Old May 3, 2017 | 02:24 PM
racer59's Avatar
racer59
Hi just dragging up a old thread, does anyone no if the vq37 front timing cover, bolts onto the vq35hr heads , we are looking at useing a vq37vhr block and fitting 35 heads to it and wanting to no if u can use the 37 front covers with 35 heads.
_koubie_
Sep 20, 2015 06:34 PM
