ATI Procharger Help
Old Apr 20, 2015 | 07:30 AM
NeoGixxer's Avatar
NeoGixxer
Default ATI Procharger Help
I'm having issues with the main cog belt rubbing against the pulley. I tried adjusting it so many different ways but it's rubbing against the pulley. The friction is damaging the pulley and the belt.
Has anyone had this issue? How do it fix it.
I'll post pics up
Old Apr 20, 2015 | 07:37 AM
NeoGixxer's Avatar
NeoGixxer
Old Apr 20, 2015 | 07:38 AM
NeoGixxer's Avatar
NeoGixxer
As u can see its rubbing a groove into the pulley
Old Apr 20, 2015 | 07:44 AM
jdm-v35's Avatar
jdm-v35
Its because the tension is too tight. The procharger is very finicky about that. too loose and you get belt slip and it eats pullies. Too tight and the tensioner gets angled and this happens. If you could find a way to brace the outside end of the tensioner bolt it would definitely fix this problem. Other than that just be very careful with tightening it.
Old Apr 20, 2015 | 09:00 AM
NeoGixxer's Avatar
NeoGixxer
Ill try it, thank u
Old Apr 20, 2015 | 10:47 AM
Conway_160's Avatar
Conway_160
Mine does the same thing.
Old Apr 20, 2015 | 05:55 PM
NeoGixxer's Avatar
NeoGixxer
I straighten out the tensioner with a washer and didn't make it to tight. It still wants to rub on that pulley. It's krazy
Old Apr 20, 2015 | 06:04 PM
2bad240's Avatar
2bad240
Take the pulley off. Then take the sleeve that sits behind it off. And lap both ends on some sand paper to make it 100% flat. I did and it helped mine a lot.
NissanZcrazy
Sep 23, 2015 07:59 AM
jesseenglish
Mar 7, 2004 02:23 PM
JoeAE2005
Jul 10, 2003 06:59 AM
OCG35Coupe
Jul 1, 2003 06:25 PM
