E85 Built Motor Oil Consumption
Old May 24, 2015 | 01:05 AM
thatv35guy's Avatar
thatv35guy
Default E85 Built Motor Oil Consumption
Hi all,
So, after my car started pushing coolant I'm gearing up for a top engine rebuild (ARP L19's & HKS head gaskets), I initially set the scope to just pull the heads but my car also seems to burning a good bit of oil... I'm burning at least a quart per 1,000 miles right now, the consumption seemed to increase after I switched to E85 about 6k miles ago.
I'm running a built motor w/Wiseco 8:8.1 compression pistons & Brian Crower rods, Rotella T6 5W40 oil and I'm regularly running the car on E85.
Anyone else have similar consumption? I'll be doing a compression & leak-down test shortly too.
Thanks!
Old May 28, 2015 | 08:31 AM
str8dum1's Avatar
str8dum1
you ever send oil to blackstone for analysis?
E85 wont cause oil consumption. The increased power will, esp if your rings were not gapped appropriately
Old May 28, 2015 | 09:36 AM
thatv35guy's Avatar
thatv35guy
I haven’t, I think I will now though…
When I was on pump gas I was burning what I’d consider an acceptable amount of oil, since I’ve switched to E85 its roughly doubled… when I got the car back from the dyno I was running very rich though, AFR on E85 was in the high 7’s, I realized it after about 1,500 miles and then pulled some fuel to bring the AFR into the 9’s. I was wondering if that might’ve done it?
Old Nov 9, 2015 | 01:47 PM
thatv35guy's Avatar
thatv35guy
Finally got my first oil sample back from Blackstone:
Attached Thumbnails E85 Built Motor Oil Consumption-blackstone_vq35_turbo_built_1.jpg
apex locator
Jul 23, 2021 02:27 AM
