Turbo Replacement
Old Oct 27, 2015 | 02:30 PM
Cannysage's Avatar
Cannysage
Default Turbo Replacement
hey guys, long time no visit.
I need to replace one of my APS (non-extreme) turbos. my car's putting out 500+ whp and I'm unable to confirm the size of the turbos. I'm fairly sure that it's a gt28. Is there any etchings on the turbos to confirm this? space is tight and I can't see anything. Also, are gt28rs the same size?
Old Oct 27, 2015 | 03:24 PM
Conway_160's Avatar
Conway_160
Well if you want to replace them you have to pull them out, so pull them out see what they are. I understand space is very tight but no time like the future to pull them out.
Old Oct 27, 2015 | 03:33 PM
Cannysage's Avatar
Cannysage
its at a shop right now. I want to make sure I can find a replacement before giving the green light on the swap.
Old Oct 27, 2015 | 04:21 PM
rcdash's Avatar
rcdash
Original APS turbos were true garrett GT2871s ball bearing center section but I believe with an APS modified turbine cover and a GT25R frame compressor housing to make it fit. Then they changed them out for some off brand journal bearing when APS started to go under...
Old Oct 27, 2015 | 04:39 PM
tonyzS/C03's Avatar
tonyzS/C03
^+1... If you are wanting to replace with GT2871's they will fit just fine, i've got the GTX versions on my car right now and its a HUGE improvement over the GT's
Old Oct 28, 2015 | 12:55 PM
Cannysage's Avatar
Cannysage
cool guys,
thanks for the helpful info.
Old Oct 28, 2015 | 03:38 PM
Cannysage's Avatar
Cannysage
only etching that could be seen was AR80
Old Oct 28, 2015 | 05:49 PM
rcdash's Avatar
rcdash
That is probably the turbine A/R, 0.86 or the compressor A/R, 0.60
Old Oct 28, 2015 | 10:43 PM
IIQuickSilverII's Avatar
IIQuickSilverII
wow OG post!.... nice!...since you are replacing turbos go with the "upgrade" option anyways
Tritan
Shop Builds
26
Jun 8, 2016 09:40 PM
dpierce33967
Drag
Oct 25, 2015 05:05 AM
xAdamLeex
Videos
Oct 20, 2015 05:21 PM
