Kinetix Velocity Manifold
Old Nov 1, 2015 | 03:01 PM
Conway_160's Avatar
Conway_160
Cool Kinetix Velocity Manifold
I'm looking for some imput on what you guys think of them. I've read the people who are N/A loose power down low and in the mid range but have gains up top. Haven't seen alot from people who are F/I. So thats why im asking in here and not in the regular intake thread.
I've heard about the not so spectacular welds that break under boost, I would hope my procharger cant do that...lol
I would also think it should stay cooler then the stock intake since its so much smaller and lighter also it being a SS should help.
Old Nov 2, 2015 | 10:38 AM
craig12895's Avatar
craig12895
I don't have forced induction installed yet so this can be ignored if you choose.
I installed my kinetix on my NA car and felt zero improvement as well as zero loss of power.
As far as the Kinetix breaking under boost, I believe that is if you are pushing a good bit over 20psi of boost. Which is A LOT.
Old Nov 2, 2015 | 03:31 PM
Conway_160's Avatar
Conway_160
Thanks for the imput Craig, but with the lack of responses this isn't looking promising.
Old Nov 2, 2015 | 03:55 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Sometimes you gotta just buy it and hope for the best. It looks awesome, and ive seen lots of threads with positive reviews on boosted velocity use. If it had better reviews for NA use I probably would have gotten one. I have the V+ and its pretty ok. That velocity just makes the engine bay look so much better.
Old Nov 2, 2015 | 04:16 PM
craig12895's Avatar
craig12895
I think what you will find is that there are positive and negative reviews on every single part out there. You just have to consider what you think you will enjoy the most.
I think that if you buy a Kinetix, you cannot assume the welds will crack. Although that does happen, it isn't the case most of the time. And if it does I would imagine Kinetix will help you out with it
Old Nov 2, 2015 | 06:47 PM
OldManZ350's Avatar
OldManZ350
I have a stock untouched manifold with a 3/8" spacer.
That may tell you just how good the stocker works.
Old Nov 3, 2015 | 10:06 AM
Shin Beats's Avatar
Shin Beats
Here you go:
https://my350z.com/forum/intake-exha...th-spacer.html
Old Nov 3, 2015 | 03:06 PM
Conway_160's Avatar
Conway_160
This is all N/A, :-( hopefully I can get this kinetix then when I go get tuned ill test the kinetix vs a stock with 5/16 spacer.
Old Nov 4, 2015 | 05:49 PM
Escobar's Avatar
Escobar
From what my tuner said, it really isnt even worth bothering getting unless your on a built block with high psi. If your NA your throwing money away.
Old Nov 4, 2015 | 05:56 PM
Conway_160's Avatar
Conway_160
Well I have a built block but only running 12-14psi.
Old Nov 5, 2015 | 08:13 AM
IIQuickSilverII's Avatar
IIQuickSilverII
kinda not worth it IMO other than N/A, just go with a spacer and polish your plenum...
Old Nov 5, 2015 | 02:18 PM
Conway_160's Avatar
Conway_160
I'm going to buy it test it to compare it to stock with soacer and if the results are not to my licking then ill sell the kinetix.
Old Nov 5, 2015 | 04:52 PM
rcdash's Avatar
rcdash
Save your time and money. Listen to the other OGs. Stock with spacer is best bang for the buck for the vq35de and the broadest powerband increase. Cosworth if you want the looks and while you do get a bit more top end it is at the expense of mid range torque. CJM if you have the cash and the set up to go all out for high rpm power (that means a front facing throttle body too!).
Old Nov 5, 2015 | 05:04 PM
Conway_160's Avatar
Conway_160
Well thanks for crushing my dreams guys...
Old Nov 6, 2015 | 10:41 AM
craig12895's Avatar
craig12895
What else is a forum for
Old Nov 6, 2015 | 02:40 PM
NissanZcrazy's Avatar
NissanZcrazy
I have the kinetix intake on my boosted Z,the manifold is always cooler than the rest of the engine,so I would assume the temps for the intake are lower.Also I love the fact that there's like 7 bolts to remove the entire intake plenum instead of like 30 lol.Gives easier access to more things also.
DeeCryme
Oct 22, 2015 03:25 PM
codek
Oct 14, 2015 07:17 PM
