Looking for help with twin turbo set up. !!!!!!
Old Mar 22, 2016 | 03:27 PM
  #121
R6n350GT's Avatar
R6n350GT
Originally Posted by 35reilly
When you guys talk about a oil sensor after the the oil pressure switch do you actually mean run a oil pressure sensor to th inside of the car? Hard to explain what is m actually trying to say I know. Lol. I have a g35 I just ran an aem oil psi to monitor oil psi. I'm confused you are running an additional gauge just for turbos as well? Or is this the oil psi gauge for oil psi as well?
Oil pressure gauge yes, just for the pressure of oil going to the turbo.
Old Mar 22, 2016 | 03:49 PM
  #122
35reilly's Avatar
35reilly
So you run a whole other gauge just for the turbos?
Old Mar 22, 2016 | 03:52 PM
  #123
35reilly's Avatar
35reilly
Wow!!! What is the psi supposed to be running to the turbos? I have greddy so there not ball bearing
Old Mar 23, 2016 | 09:29 AM
  #124
rcdash's Avatar
rcdash
Originally Posted by rcdash
The filter goes on the feed line to the turbos, of course. I have mine before the tee that splits to each turbo. The oil psi recommendations are different for journal vs ball bearing. 5-10 psi at idle, 30-40 psi max rpm for ball bearing turbos. I have the .035" restrictors on the turbos and the filter, which is also .03", running 4AN lines. I originally tried a filter with .05" orifice and I had a little leaking of oil around the center section until I went to a smaller size.
For journal bearing, I think 1/8" orifice is correct with no other restrictors. They need a lot of oil to cool the bearings.
I have been changing filters twice per year, but hardly see a few flecks so will probably change filter annually. The filter does catch these tiny black deposits.
EDIT: Here is the reference link for psi required for different turbos, http://www.turbomaster.info/eng/bulletins.php?id=31
I quote myself for the link to the oil pressure ranges!
HRMoneyPit
Jan 12, 2016 08:49 AM
WillyP28
Nov 23, 2015 02:59 PM
DesertSleeper
Nov 5, 2015 01:07 PM
NA&CH
South East Marketplace
Nov 2, 2015 03:33 PM
