Looking for help with twin turbo set up. !!!!!!
Old Nov 30, 2015 | 05:31 PM
  #101
travlee's Avatar
travlee
Master
from socal own purty mouth
Originally Posted by SoCal_VQ
you were on a hub dyno correct? I got 57k on my car idk if that plays much of a role. I know hub dynos have a history of reading "high" or maybe load based dynos just read inaccurately low.
https://my350z.com/forum/tuning/6053...l#post10625897
also in the same thread
Originally Posted by michaelmoon912
Church's dyno is notorious for reading extremely high, take it for what you will.
Your numbers are good for a de, no odd dips. Congrats man
Old Dec 1, 2015 | 12:45 PM
  #102
35reilly's Avatar
35reilly
Ok back on track. So someone tell me. 18gs are good for how much? Where are they maxed out at?
Old Dec 3, 2015 | 11:01 AM
  #103
str8dum1's Avatar
str8dum1
mid 700 range
Old Mar 17, 2016 | 03:53 PM
  #104
35reilly's Avatar
35reilly
Originally Posted by str8dum1
mid 700 range
Thanks man. Kinda let this issue go for a while do to other things that popped up. Ok so since my power goal is 750 plus I guess I need to look into the 20g upgrade. If I upgrade to the 20 and leave the terbine like I was told from boost lab, is it true that I will be restricted with the exhaust side? Shouldn't I do the whole thing? Compressor and terbine upgrade?
Old Mar 18, 2016 | 06:39 AM
  #105
yosip1115's Avatar
yosip1115
Greddy and their trash manifolds smh seems like every Greddy tt kit has this problem.
Any tube style stainless options for greddy guys? Seems like a niche someone can dominate...
7lbs and right under 400 tq on any dyno yes I'm content with that. I don't chase quarter mile numbers I don't track. I do highway pulls and I have fun win or lose.
So... When a SC guy says he has 400 foot pounds of torque it is at the tip top of his RPM spectrum.
When a turbo guy says he has 400 foot pounds it is across more than half of his RPM spectrum.
SC area under the curve is essentially the area of a triangle .5*B*H with B being RPMs and H being his peak torque. A turbo guy's area under the curve is the area of a rectangle L*W with L being RPM's and W being his peak TQ.
😂😂😂 I think I might of hit a nerve here. Don't be mad at me because you spent 20+ k on boosting your car and have endless problems with it while I spent under 7k and will smoke that aaaassssss! You probably couldn't even get traction on the street in 1st 2nd or 3rd basically useless for you 😂😂😂😂
You really think you would smoke him? This is too good to be true.
One last thing tho. If turbo setups are so reliable and worth it why did all the major brands like momentum, gtm, Greddy all stop manufacturing their kits for the vq??? Hmmmm...
Something nobody mentioned is the fact that Greddy is currently re-engineering a version 2 TT kit for the 03-06 DE engines. Lol.
Originally Posted by kilogram
Don't bother upgrading to 20g compressors. They are ancient tech and they're a horrible match to half of a 3.5L. They also surge like crazy above 18psi at sea level, 14psi at elevation.
There are billet 18g wheels that will outflow them available now. I've run the KTS 7 blade ET 20g wheel and it spools faster and outflows the standard 20g by about 25%. The smaller wheels perform about the same. It's not even worth bothering with the old cast wheels anymore now that billet wheels are available and cheap.
There are also superlight turbine wheels as well, and all of these parts drop directly into a standard MHI turbo cartridge and housings. MHI turbos (Greddy are all Mitsubishi Heavy Industries turbo cartridges) are component balanced (each part is balanced individually), so as long as the turbine hasn't touched the housings you can reassemble it in any orientation and it will retain balance. Those of us who have worked on MHI turbos have been rebuilding them this way for about a decade.
It's also worth upgrading the thrust bearing hardware with the larger bearing and double hole oiling plate. Kamak developed this kit about 7 years ago to deal with higher thrust loads from the billet wheels, and it's basically a copy of what Holset uses in their oiling system. It's a 360° bearing (all TD05/6 frame use a 360° bearing, FWIW) with two oiling holes and a larger diameter bearing surface. I've had turbos survive horrible on-throttle surge with this bearing with zero damage- surge that would have killed a standard MHI bearing (secondary intake butterflies got stuck closed causing the surge).
There are plenty of shops that can rebuild turbos (GpopShop, TurboLab, or any DSM shop can handle MHI turbos), or if you're even remotely mechanically inclined and have a decent snap ring pliers, you can do it yourself. It's really not difficult at all, just keep everything clean.
And make sure you're using a suitable oil feed for your turbos. The pressure sensor is unfiltered oil. MHI turbos are nearly indestructible if you feed them clean oil at the correct pressures.
Original reason I started multi-quoting...
So you Z guys have a oil pressure sensor, and the oil pressure switch like the G's have. Is the pressure switch filtered? That is where the greddy instructions have you tap in to feed the turbos... If that isn't filtered I need to address that somehow. Possibly tap into my cooler sandwich plate.
Old Mar 18, 2016 | 07:13 AM
  #106
rcdash's Avatar
rcdash
No the pressure switch is not filtered. Run a "forced performance" inline filter. I also run a pressure sensor AFTER the filter so I can monitor if the filter is getting clogged and see what pressure the turbos are seeing. Please note that there are two versions, one for journal bearing turbos and one for ball bearing (smaller .035" hole).
EDIT: Here it is... http://www.forcedperformance.net/PROD/FP4ANFilter.html
Old Mar 18, 2016 | 08:45 AM
  #107
35reilly's Avatar
35reilly
Where do u put these filters? Also what should the oil psi for the turbos? I basically put my sensor where the greddy feed lines are coming out of the pan. Is there something better I should think about? I'm upgrading all the feed lines to an anyway. Just want as much precaution as I can
Old Mar 18, 2016 | 10:05 AM
  #108
yosip1115's Avatar
yosip1115
1/8" orifice, correct? How long do they last you before you need to clean/change the filter?
Old Mar 18, 2016 | 10:46 AM
  #109
rcdash's Avatar
rcdash
The filter goes on the feed line to the turbos, of course. I have mine before the tee that splits to each turbo. The oil psi recommendations are different for journal vs ball bearing. 5-10 psi at idle, 30-40 psi max rpm for ball bearing turbos. I have the .035" restrictors on the turbos and the filter, which is also .03", running 4AN lines. I originally tried a filter with .05" orifice and I had a little leaking of oil around the center section until I went to a smaller size.
For journal bearing, I think 1/8" orifice is correct with no other restrictors. They need a lot of oil to cool the bearings.
I have been changing filters twice per year, but hardly see a few flecks so will probably change filter annually. The filter does catch these tiny black deposits.
EDIT: Here is the reference link for psi required for different turbos, http://www.turbomaster.info/eng/bulletins.php?id=31
Old Mar 18, 2016 | 11:58 AM
  #110
yosip1115's Avatar
yosip1115
Honestly my one problem is the fact that I don't know if my 18g's are ball or journal... Shame on me. I trusted the feed lines I ordered because the fittings had restrictions on them already. I am thinking I can't go wrong with the big orifice filter as long as the fittings still have restriction regardless of what type of bearing my turbos have. Any input?
Even if I had a pressure sensor after the filter I wouldn't know what pressure the bearings are seeing after the restriction fitting unfortunately.
Old Mar 18, 2016 | 01:46 PM
  #111
35reilly's Avatar
35reilly
I was under the impression that you just need like a 4an line for the feed. There is a certain siZe you need to go with? I'm planning like u said earlier to run an lines. Can anyone refer me to a site I can get all the fittings to change over and also what the correct lines I need?
Old Mar 18, 2016 | 01:49 PM
  #112
35reilly's Avatar
35reilly
What exactly are the restictions you are talking about? I'm sry if I don't understand trying to not make a mistake with changing all the feed and return lines. Any pics?
Old Mar 18, 2016 | 01:57 PM
  #113
yosip1115's Avatar
yosip1115
Email stan@fast-turbo.com for their greddy 350z feed line kit. $85 for everything. Great quality too!!
Old Mar 18, 2016 | 02:01 PM
  #114
35reilly's Avatar
35reilly
Thanks bud. I definitely will. This is something else am definitely doing. Btw do you know for a company that is very well trusted to upgrade the 18g to 20g ? I'm getting close to Having to send out.
Old Mar 18, 2016 | 04:48 PM
  #115
rcdash's Avatar
rcdash
Greddy turbos use journal bearing and rely on the oil for cooling (no coolant flow). 4an should be sufficient to feed both turbos.
Old Mar 19, 2016 | 02:21 PM
  #116
bealljk's Avatar
bealljk
take a deep look inside your CHRA, there is an small hole that feeds the bearings...you can use an AN -8 but that hole will only allow so much oil into the bearings. I run an AN4 off my post-filter port and then I 'Y' it to AN-3s before the turbos.
food for thought...
(that's a piece of teflon tape, not a metal shaving)
Old Mar 20, 2016 | 12:17 PM
  #117
rcdash's Avatar
rcdash
twin 3ANs is fine too!
Old Mar 20, 2016 | 01:31 PM
  #118
35reilly's Avatar
35reilly
Been reading about compressor surge with the 20g twins. Has anyone experienced this? Sry it's off the feed topic.
Old Mar 22, 2016 | 04:27 AM
  #119
R6n350GT's Avatar
R6n350GT
I did this myself
https://my350z.com/forum/forced-indu...l#post10733261
But i will be changing the push lock hose to series 200. It comes from oil pressure switch and then the -4AN going to tubro has NPT fitting with oil sensor (put in since photos) so i can monitor turbo getting oil. That way less chance of it getting blocked and can be changed every 2-3rd oil change.
Old Mar 22, 2016 | 05:07 AM
  #120
35reilly's Avatar
35reilly
Originally Posted by R6n350GT
I did this myself
When you guys talk about a oil sensor after the the oil pressure switch do you actually mean run a oil pressure sensor to th inside of the car? Hard to explain what is m actually trying to say I know. Lol. I have a g35 I just ran an aem oil psi to monitor oil psi. I'm confused you are running an additional gauge just for turbos as well? Or is this the oil psi gauge for oil psi as well?
