Bottom end short block question
from your phone from your pc make it easy to read and proof read ... you'll get better & more response from fellow members.
mishi sucks eitherway ... I run two Setrab oil coolers and a C&R Racing nascar hammy-down ... but that's me
I've been a member of this forum (form is something you fill out at the DMV) for twice as long as you have - lol! and I've been running some form of FI on a stock and then a built block since 2007 ... just saying...
my single 42 garrett spools in a fraction of the time my greddy twins took ... not to mention the significant reduction in lag-causing intake-charge pipe tubing required for twins.
Well as stated before opinions .... So glad for Grammer *****. Also I'm not having who has the bigger dick competition. I've got my answers already thank you for your time. (Mods) lock thread please before this blows up my only question was if a d.e. short block is the same as the rev up I didn't care to have this form soiled like every other one I try reading for my knowledge. P.s. I've built 4 cars already iv had a twin 06 gto that was at 874whp and as any ls2 block it held very well. Intil I wrecked it because a wheel bearing locked. I've been racing for the last 13 years and have 2 wins under class B track. So quit being a troll and saying something someone else has sucks it's really immature. It's sad people still cyber bully I might not know or care to separate my sentences but I can still build a engine and race really well. This is the reason I don't post and just use the search function. Thank you for your time. don't worry about posting again I won't reply to feed your ego again. I'll just go the next 4 years again with out posting intil I have another question. P.s. look at all my post I've ever done I can actually say I've done everything with out a shop or help just reading and searching..... when I get finish building mine I will gladly see what your single will do vs. a twin there is no replacement for displacement. Bye! :P
wow - first time I've ever been called a troll and/or a cyber-bully! point-taken and all the best with your build!
Not sure why you would want to bore out a closed deck block. You’re just creating a lot more heat.
I think everyone here is having difficulty on what you’re trying to say. You keep typing in circles rather getting to the point of the question or reply.
Nobody here is is trying to insult your build, mostly it’s just curious questions on why you’re going the route you chosen. Also it’s common for someone to have all these plans and not go through with it, so I’d imagine a few people would be skeptical.
By definition, doesn't a short block include the rotating assembly ?
If so, then the short blocks would not be the same.
Perhaps a better description would be "BARE BLOCKS" ???
Srivero297
Feb 14, 2006 02:24 PM
creationv2
Oct 31, 2005 10:27 AM
