what guages do I need??
Old Mar 18, 2004 | 10:10 AM
tig488's Avatar
tig488
Default what guages do I need??
alright I need some help deciding which gauges I need to buy, Ive been told different things so I figured I would ask you guys. I am installing the vortech sc on my g35 coupe with the split second box, i was gonna get teh apexi s-afc2 but my tuner told me not to. i was told to get a fuel pressure, oil pressure, and boost gauge, is that it? what about A/F or EGT?
I need some answers quick! What do I need?
Old Mar 18, 2004 | 10:56 AM
teh215's Avatar
teh215
Definitely get a wideband A/f gauge, the EGT is probably optional although I got one instead of the oil pressure gauge.
Old Mar 18, 2004 | 12:21 PM
tig488's Avatar
tig488
what about electrical vs mechanical. is there any difference other than installation?
Old Mar 18, 2004 | 12:30 PM
booger's Avatar
booger
I just ordered my Vortech also . I am getting a wide band 02 and Im looking to find a dual digital gauge for boost and fuel presure.Want to put them in the cubby hole where the nav. goes. There is only room for 2 so thats why the dual gauge .Any one know where I can find the dual gauges at ? Ive seen them on a site but cant remember where
Old Mar 18, 2004 | 12:51 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Mechnical boost gauges use a vaccuum line that runs all the way back to guage to generate the reading. An electronic unit send the signal back to the guage via a standand electrical wire. Theoretically, the electronice guage is more accurate and reliable, since you eliminate the possibility of a kicked vaccum line running back to the guage which could throw off the reading. Electronic boost guages are also more exepensive. I ended up going mechanical becuase I couldnt find an electronic guage with PSI readings...only BAR. Hope that makes sense.
Regarding which guages to get, I only wanted two gauges, so I chose boost and Wide Band O2. Fuel pressure and oil pressure are probably more useful in higher HP application. In an ideal world, I would get a full assortment of guages, but due to space and mounting contraints, I went with the two most important...in my opinion.
Old Mar 18, 2004 | 01:07 PM
dollar99's Avatar
dollar99
I think wideband guages are useless unless it has logging capabilities.
Old Mar 18, 2004 | 01:22 PM
Sharif@Forged
Forged Performance
I disagree with that statement. It's helpful for dyno tuning, and more accurate than a tailpipe reading. Also useful while driving to observe AF levels...it's more of a safety issue...so you know you aren't running overly lean...I think that would be good to know.
Old Mar 18, 2004 | 01:38 PM
fluidz's Avatar
fluidz
Where can I buy a AEM WIDEBAND A/F METER and get it by Tuesday?????????????HELP!!!!!!
Old Mar 18, 2004 | 01:54 PM
fluidz's Avatar
fluidz
never mind about the AEM A/F meter, Jason at performance has them in-stock and just sent me one, will get it on Tuesday!!!!!!!
Old Mar 18, 2004 | 02:33 PM
teh215's Avatar
teh215
I am using the Autometer A/F gauge driven by my PLX wideband controller so that it is 100% accurate. I like this setup since I can keep all of the gauges with the same theme plus I still have a digital readout on the PLX display.
Old Mar 19, 2004 | 08:25 AM
dollar99's Avatar
dollar99
yes, but how accurate can it be when it can't log data vs. the rpm? How can someone possibly read the RPM on the tach and read the readings on the guage at the same time?
Old Mar 19, 2004 | 08:37 AM
teh215's Avatar
teh215
I think that the point is you do not want to see any high readings on the display while driving that would indicate you are running lean. If you do see them, you can back off until you get the problem resolved. I would probably not use it for dynoing unless the dyno can accept the output from my controller. My 2¢
daking350
Jan 4, 2004 04:50 PM
polar
Aug 6, 2003 08:48 PM
mucky
Apr 12, 2003 09:35 PM
Raptor303
Feb 3, 2003 10:09 PM
JDZ
Sep 15, 2002 04:20 PM
