eManage wiring help
Old Apr 27, 2004 | 05:11 PM
derek_i's Avatar
derek_i
Default eManage wiring help
OK, all the wiring for the eManage is accounted for (including the mis-labeled pin 119) with the exception of one wire, injector #4. On the GReddy instructions, it shows pin 8 (purple/red) going to pin 41 (white/red) on the ECU. On my car, pin 41 is white/black.
Did anyone else run across this? I would have seen it like the red/white pin 119 problem. The shop placed a call to GReddy and was told a technican will call them. This was 2PM their time (PST) and no call by 3:30PM (PST) at which time the shop closed. I called GReddy 3:30 their time and was told the same thing, that a tech would call me. No call as of 6 PST. This was after the guy at GReddy hung up on me when I asked when the technicans would be available.
I recall a recent GReddy vs. PE post where someone pointed out that GReddy had stateside support and PE didn't, which was an advantage. Well, I have a dyno appointment in the morning and my car is useless until I figure out why GReddys diagram is different, and GReddy won't open until 12PM my time. Pretty good support.
-D
Old Apr 28, 2004 | 05:38 AM
derek_i's Avatar
derek_i
bump
I'm heading to the shop this morning and was hoping someone would know a solution. Should I tap into the white/black in pin 41 even though GReddy shows it as white/red?
Thanks,
-D
Old Apr 28, 2004 | 05:42 AM
g356gear's Avatar
g356gear
Go by Pin Location not color. Check the service manual for the injector # and corresponding pin location.
Old Apr 28, 2004 | 06:11 AM
derek_i's Avatar
derek_i
This is why this forum is so great. I'm a little embarrased that I didn't think of that. I did a search for the manual in PDF (seach works again!) and sure enough, pin 41 white/black is injector #4.
g356gear, you are the man.
I wonder why this is the first occurance of this in the forum?
-D
Old Apr 28, 2004 | 08:09 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
I saw the same thing when I was reviewing my wiring. There a few miscolored injector wires and ignition wires. But it's easy to just trace it back to the pin.
Old Apr 28, 2004 | 06:07 PM
derek_i's Avatar
derek_i
Just an update. I initalized the eManage and re-entered the maps using the E-01 remote (not fun, trust me). I programmed the car setup and boost settings for auto-learn at 6 psi. Everything looked good until the eManage started flashing green/red over and over. It wasn't reporting a code, just continuous flashing. The car also threw a check engine light. We were stumped so the tuner called GReddy again (now it's the next day and they never returned either call from the previous day). My tuner was told that the techs would be back in 2 hours, so we waited. 2 hours later, a very rude person at GReddy (he said his name was "Jod") said the techs would be back in the morning. My tuner pushed for a better answer and was told the techs would not speak with him since he wasn't an authorized GReddy dealer. This goes along with me being told that the techs "didn't want to talk to me" (exact quote) the previous day.
Turns out the installer plugged the Overtake Boost into the meter plug, not the option plug. I re-initialized the eManage, downloaded the maps I did earlier to it (thank god I saved them), and reset the ECU to clear the CEL. Everything looks good for a dyno run tomorrow.
So in short, GReddy sells a $7000 kit with bad instructions (at least 2 mis-labeled wires) and when you call them for a little help, they give you the big "F U". Nice. Something to think about for those trying to decide between GReddy and PE as the PE kit is getting cheaper.
-D
Old Apr 28, 2004 | 11:01 PM
Sharif@Forged
Forged Performance
Derek, I have personally called Greddy at least 5 times, and each time, they were polite, and I was able to get right through to Kenji who is their lead tech/owner/driver of the blue 350 GreddyZ TT that's on their website.
One time, i called for installation help for my Greddy Evo2 exhuast. The front desk guy took a message, and Kenji called me back in 5 minutes. Your experience with Greddy is not consistent with what others have posted.
By the tone of your post, maybe your installer was a bit too pushy or something. Also, keep in mind that Greddy gets 100's of calls each day for tech support, so it might take then a couple days to get back to you.
Any good installer knows to NEVER rely in wire colors. It's a fricken rats next back there, and there are mulitple wires with the same or similar colors. One should always go by the pin location..not color.
Lastly....the Greddy kit is only $6000...not $7000 based on typical street prices.
Glad your car is working now.
Old Apr 29, 2004 | 12:47 AM
ACP's Avatar
ACP
Plus they are short 1 tech, as Matt is no longer there.
He use to take the majority of the calls
And GG the $7,000 price Derek is stating, is WITH install (for him atleast )
Glad you figured it out Derek
Old Apr 29, 2004 | 06:06 AM
derek_i's Avatar
derek_i
I should clear this up. The price I gave includes some other toys (E-01, ignition harness, accessory harness, link, overtake boost controls, turbo timer and more). I did a lot of research on whether to go SC or TT, and when I decided on the GReddy kit, I did more research on price. I got some good pricing for the kit with FMIC, but no one came close to ACP's price (also Eibach and some Kenetix goodies).
GQ:
Maybe you're right and we happened to get the wrong person both days. I personally called twice, and I was very polite both times. I think the people on the board are much more helpful
Speaking of which, I would like to start a thread with you and ETX concerning E-01 set up. I'm thinking of teaching it low boost at 6.5, high at 7.5 and something for the overtake. It would be nice to start discussing the timing map as well.
-D
Old Apr 29, 2004 | 07:40 AM
etx's Avatar
etx
Well I still have not dyno tuned my car. No time.
I am pulling 3 digrees at 5.5 and 7 at 8 psi. I have not run 8 psi yet, but it's there incase I get a little spike.
Setting the boost on the e-01 is really simple, and the autolearn function actually WORKS. What a concept.
Old Apr 29, 2004 | 07:57 AM
derek_i's Avatar
derek_i
I'm afraid to drive it without the dyno info since I reset the eManage and erased GReddy's presets. I put in the two maps previously mentioned, but what if there was more?
I can't pull timing yet because Radio Shack only had 4 of the 6 diodes I need to complete your modifications to the harness.
Did you get the Zt-2 logging to your E-01 (from an earlier thread)? I had an extra bung put in the driver-side test pipe and want to get A/F readings ASAP.
-D
Old Apr 29, 2004 | 03:44 PM
Sharif@Forged
Forged Performance
If you have the stock greddy fuel table, you will be fine. No worries.
You only have to enter data inthe "Add injector table", and the Boost Cut Limiter. (5V across the board). Then scale your injectors from 300cc to 440cc. That's it.
I agree...once everyone gets their ignition harness and timing adjusted/dynoed, maybe ETX can begin the thread since he is the resident eManage expert, and I am just the little grasshopper in training. .
350Z_Al
Oct 29, 2020 07:44 PM
bcoffee20
Nov 19, 2015 06:39 PM
nanotech
Oct 2, 2015 05:02 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
