Life expectancy of turbos
Old Apr 29, 2004 | 03:14 AM
hurahn's Avatar
hurahn
Default Life expectancy of turbos
How long are they going to last? Do you change yours at a set mileage or do you wait for tell tale signs that they are going bad? Thanks.
Old Apr 29, 2004 | 04:39 AM
PoWeRtRiP's Avatar
PoWeRtRiP
depends entirely on how you treat them, if your good to them expect at least 100k life span, if bad they may not last more than 10k.
Old Apr 29, 2004 | 06:44 AM
etx's Avatar
etx
If your bov is adjusted properly and you don't starve them for oil they should last the life of the car.
Signs of them going bad, Motor burining oil. If the seals on the shaft go oil will get into the compressor housing and be sent off to the cylenders to be burnt.
Shaft play, If your compressor wheel is touching the wall of the compressor housing or moving in and out a lot your turbo needs a rebuild.
Old Apr 29, 2004 | 07:40 AM
PoWeRtRiP's Avatar
PoWeRtRiP
cool thing is even a rebuild on a turbo is cheap, and when its done it is practically a new turbo, or it could be an excust to get bigger ones!
Old Apr 29, 2004 | 04:32 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Change oil/filter every 3000miles with a quality synthetic oil, and establish proper cool-down practices, and the turbos should last the life of the motor. 100K or so.
Old Apr 29, 2004 | 04:57 PM
Yellow Stealth's Avatar
Yellow Stealth
As you can tell from my sig, I have had my twin turbo for 10 years and have 125K miles on them. They are going as strong as new.
Here are the 2 secrets I believe saved my turbos:
1 - Changed oil every 3000 miles religiously (engine and turbos share the same oil in the Stealth)
2 - Always let my engine warm up for a couple of minutes and ALWAYS let them cool down for at least one minute. That can be achieved either with patience or a turbo timer (which costs under $100)
Old Apr 29, 2004 | 04:58 PM
Enron Exec's Avatar
Enron Exec
Yep, isnt technology grand?
Old Apr 30, 2004 | 04:39 AM
PoWeRtRiP's Avatar
PoWeRtRiP
hey i got 150k out of the stock 9bs in my stealth before they started leaking oil, im surprised you havent swapped them out for an upgraded set, they are very small stock
May 30, 2017 03:28 PM
codek
Sep 28, 2015 03:03 AM
