Greddy TT--2004 ECU Warning--Must Read
Old May 10, 2004 | 08:07 AM
etx's Avatar
etx
Greddy made the fuel map rich to avoid the 'pinging'. A rich mix will burn slower. They should have waited or figured out some kind of ignition solution. I only boosted my Z three or four times before I installed the ignition harness to pull timing, Even with 93 octane gas! 10.*:1 comp+ 25-30 degrees of timing advance PLUS boost is generally a recipie for disaster.
Old May 10, 2004 | 09:36 AM
350Now's Avatar
350Now
ETX, how much timing are you pulling? I'm working on getting my ignition harness with diodes on and wanted to know if there is a formula here. Or is it just by playing by ear for pinging?
Old May 10, 2004 | 01:34 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
I would borrow a freinds OBD2 logger and using that coupled with an EGT and AFR gauge, you should be able to tell where to pull timing, if you need it at all.
Also, getting a real fuel system put in the car is probably your best overall bet IMHO.....costly yes, but definately the safest route
Old May 10, 2004 | 02:00 PM
350Now's Avatar
350Now
Thanks Adam. I will definitely need to address the fuel system in the future as well. Thanks again.
Old May 10, 2004 | 07:18 PM
IceY2K1Max's Avatar
IceY2K1Max
One more idea, when I was searching on the differences between the 350z and my cars' injector, I was told by the Nissan parts guru that I had the *SAME* part number injector as a 2003 350z, ie 290cc, but that Nissan used a different part number injector for 2004 models.
So, *IF* they went to a somewhat larger injector in 2004, they would have used different fuel maps possibly with a shorter injector pulse width to accomodate the larger injectors. So, if GReddy based their eManage maps on the 2003 350z's longer injector pulse width maps, they'd have less fuel on the 2004s.
Just a guess until somebody flow tests a 2004 injector to see if there is a difference.
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
