Data log Fuel Pressure to E-01
Old May 21, 2004 | 09:01 AM
derek_i's Avatar
derek_i
Default Data log Fuel Pressure to E-01
Has anyone been able to do this? I've been looking for an electric fuel pressure sending unit that will output an anolog voltage to my E-01. I know this can be done with the GReddy warning gauge and meter cable, but that is very expensive (and I don't want a gauge).
Thanks,
-D
Old May 21, 2004 | 09:19 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
get an autometer 0-100psi fuel pressure sending unit. t32gzz and i have this. it needs to run off of 5v, so you need to tap for it or make a regulated 5v power supply. you will also need the wiring harness for the sending unit (does not come with the sender alone, only with complete gauge kit). the output is linear, also: 0.5v =0psi, 4.5v=100psi
hth,
michael
Old May 21, 2004 | 09:31 AM
derek_i's Avatar
derek_i
hth,
michael
Thanks Michael,
Do you recommend any particular place to get this? Summit Racing lists the AutoMeter 0-100 psi sending unit for oil pressure but not fuel (same thing?) and I didn't see it on Jegs.
-D
Old May 21, 2004 | 10:43 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
http://hp.autometer.com/products/acc...t_senders.html
Fuel and Oil 0-100psi (full sweep): part number 2246
michael
ps. you will have to order the harness for this directly from autometer.
Old May 21, 2004 | 11:50 AM
derek_i's Avatar
derek_i
michael
Thanks again Michael,
Autometer doesn't sell the wiring harness, but they connected me to the service dept and they are going to pull one from the repair bin and send it no charge, very cool.
Ordered the sending unit (2246) from Summit Racing.
-D
Old May 22, 2004 | 09:14 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
excellent, derek! bob from autometer support sent me one also
good luck!
m
Old May 23, 2004 | 07:14 AM
ACP's Avatar
ACP
Looking to do the same thing
Can you tap into other electric fuel pressure gauges like this as well ?
I picked up Defi D-Gauge I wanted to try to connect to my e-01...
Old May 23, 2004 | 10:38 AM
350Now's Avatar
350Now
Same here.. I have the DEFI D-Gauge fuel pressure gauge. Can I tap the sending line and log the fuel pressure? Using a Greddy Profec E-01 for logging.
Old May 23, 2004 | 05:43 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
you can tap anything that is 0-5v, and you know the conversion. a simple DVM will be able to let you see if it's 0-5v, and also with 2 people, you could match up voltage to fuel pressure...
m
Old Nov 29, 2004 | 04:24 AM
ether's Avatar
ether
did anybody manage to log info from the DEFI D sensors? want to eventually do this myself.
apex locator
Jul 23, 2021 02:27 AM
