JWT Oil Pan Spacer
Old May 30, 2004 | 12:54 PM
Bini2's Avatar
Bini2
Default JWT Oil Pan Spacer
The install was pretty straight forward. The guys from Z1 Motorsports did the install. It took them about 20-30 minutes. The took off the oil pan, cleaned all the surfaces, silicon, and put it all together.
I don't have an oil telp gague, but my water temp is now lower, so I am sure this is doing something .
Great mod, I totally recommend it.
Old Jun 1, 2004 | 12:41 PM
t32gzz's Avatar
t32gzz
I added this as well to my Greddy kit. For $100 it is definitely a worthwhile mod. We had to bend the Greddy oil return line to get the Greddy pan back on. Just fyi for the Greddy guys.
Old Jun 1, 2004 | 12:46 PM
ct roadster's Avatar
ct roadster
One question: does this spacer include a longer pickup tube for the oil pump too, or is the pump pickup left at the stock height?
Thanks,
-frank
Old Jun 1, 2004 | 01:10 PM
Bini2's Avatar
Bini2
Thanks,
-frank
It does not come with a longer pick up.
Old Jun 1, 2004 | 02:08 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
in the pic on their site, it shows something that looks like a spacer for the pickup... it is the shiny metal thing inside above the 2 long bolts..
see here:
when looking at the shop manual, this is the same shape as the stock pickup.... are you sure this does not lower the pickup?
m
edit: here is a pic from the service manual.. notice the oil strainer has the same shape/size. seems to me like JWT includes a spacer for the strainer, to lower it the same amount.
Old Jun 1, 2004 | 02:42 PM
zxsaint's Avatar
zxsaint
Fairlady Stalker
I thought the benefit to this was to get it pre-tapped so that you wouldn't have to drill your oil pan?
Old Jun 1, 2004 | 05:53 PM
whosdady's Avatar
whosdady
Any others with this spacer? I called today and they are in stock. If I can get it to Crawford in time I will have them install it.
Old Jun 1, 2004 | 06:31 PM
G3po's Avatar
G3po
Default pan spacer
zxsaint..
The spacer sold by JWT is intended to simply add oil capacity .
The version with oil line taps is intended to "only" be sold with the upcoming TT kit. So if you want to avoid drilling the upper pan for Vortech etc., you would need to buy this spacer and modify it. You would need to drill ,tap and add a "J" shaped pipe into the inside to get the drain level above the OEM oil level.
Maybe Jim W will change his marketing plans and sell the TT pan individually if enough people show interest?
Old Jun 1, 2004 | 09:43 PM
AmyCroft's Avatar
AmyCroft
Default Un Taped - for NA - Question
I'd use it on my N/A - What increase in capacity?
Cheers Amy -
Old Jun 1, 2004 | 09:57 PM
Bini2's Avatar
Bini2
Default Re: Un Taped - for NA - Question
+1 Quart
Old Jun 2, 2004 | 06:10 AM
whosdady's Avatar
whosdady
How much was the install?
Old Jun 2, 2004 | 11:24 AM
ChrisMCagle's Avatar
ChrisMCagle
Any clearance issues on lowered Z's with this spacer? Seems like a good idea for the Vortech, but not at the expense of clearance.
Old Jun 2, 2004 | 12:08 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
just in case anyone wanted them... here are the install instructions: http://www.jimwolftechnology.com/wol...STRUCTIONS.pdf
michael
Old Jun 3, 2004 | 11:54 AM
t32gzz's Avatar
t32gzz
Michael is right. It does come with the extension for the pick up, at least mine did.
As far as the oil tap lines, you cannot buy them pre-drilled even though pics on the website show it. This will not be release until the JWT TT kit is released.
Old Jun 3, 2004 | 12:19 PM
Jeff@Performance's Avatar
Jeff@Performance
Performance Nissan
We've never done this yet... But looks like I need to try one of these. I just checked the warranty manual for install times. Book shows less than an hour to R&R the lower oil pan... BUT if you want to add the part for the oil pick up you need to add almost 3 hours????? Am I missing something here...
Old Jun 4, 2004 | 07:27 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
jeff: should only take 15 more minutes. this includes removing the 2 bolts, lowering the strainer, cleaning it off, reapplying RTV sealer, and re-bolting with spacer in place....
hth,
michael
Old Jun 4, 2004 | 10:23 AM
ChrisMCagle
hth,
michael
Yeah, just by looking at the installation instructions it doesn't look like more than a 30-45 minute job from start to finish. Although a lot of people said that CATS were easy to install too and that took me around 8 hours to do sooooo......
-Chris
Old Jun 4, 2004 | 11:55 AM
Jeff@Performance
Performance Nissan
Thanks guys.... we have 2 of you out there that have scheduled this to be done. So I guess I'll say labor will be $70.00 max.
Old Jun 6, 2004 | 01:11 PM
t32gzz's Avatar
t32gzz
Chris, no clearance issues, I am sitting on the front tires, lowered 1.8" in the front. Just fyi.
Old Jun 6, 2004 | 01:45 PM
NY 350Z's Avatar
NY 350Z
how much more oil can you put in?
