woohoo toasted a motor today
Old Jun 18, 2004 | 08:37 AM
  #81
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
The ECU drives the coils. Same reasoning behind the eManage. The reason the eManage can retard timing and add IPW is becuase it has drivers for both.
Old Jun 18, 2004 | 08:46 AM
  #82
Nick@StreetRyde's Avatar
Nick@StreetRyde
just curious some of the ls1s i work with have coil on plug with drivers in the coil. changes how i'm going to redo the ignition system.
thanks
Old Jun 18, 2004 | 09:16 AM
  #83
g356gear's Avatar
g356gear
Originally posted by Nick@StreetRyde
its the greddy oil pan.
thanks joe nismo. i think i'm going to replace the ignition, redo the fuel system, and redo the intake plenum.
but for the plugs i was running lfr6aix-11 the iridiums.
soo...
from what i've put together from the pieces i remember. (since i haven't actually touched the car in 2 days to get the e-01 data) i may have tuned it too lean with not enough timing retard. since it was cyl 5 i "assume" since i did not have 6 egt probes it may have been running lean in that cyl even when i had it at a 12.4 af ratio out the tailpipe on the wbo2.
hopefully when i get a chance to pull the heads off i can really see the conditions of the motor.
Off to work more info this weekend
That's not the Greddy oilpan....the Greddy one from the kit is a stock one with the returns welded on it...and it is black. Is this pick even from the 350Z engine that was apparently blown up??? or another car that was blown up before??
Old Jun 18, 2004 | 11:09 AM
  #84
derek_i's Avatar
derek_i
I was waiting for someone to pick up on that...
-D
Old Jun 18, 2004 | 06:14 PM
  #85
ACP's Avatar
ACP
That is why I was asking....
Old Jun 18, 2004 | 06:31 PM
  #86
Nick@StreetRyde
ok. whatever.
i have a cast aluminum pan with the words "greddy" on it. i'm tired of these idiotic posts.
i quit posting on these boards.
if you have any "real concern" of what happened you can email me.
nick@streetrydeperformance.com
i will no longer be checking these forums.
Old Jun 18, 2004 | 06:44 PM
  #87
CaneZMD's Avatar
CaneZMD
Come on, Man. Don't leave. All of us FI guys can use as much info on a blown motor as possible. So let us know when you figure out what happened.
And by the way, where did you get the pan? (Seriously) I like the APS pan that's coming out and the pic of the pan that you posted looked similar. (interior baffles, etc.) Does it have any exterior fins or additional oil capacity?
Old Jun 18, 2004 | 08:29 PM
  #88
d8abusa's Avatar
d8abusa
Talking
HAH! you guys are like a wet dream gone bad.
Before all the facts are laid out the POSERS are already beating up the post and yelling BS.
Here was someone willing to divulge about his disasterous install, regardless of where fault would be found. Before he could even complete his diagnosis the losers were already flexing their egos.
Good going, now we can all benefit less from your contributions to this post.
Old Jun 18, 2004 | 11:53 PM
  #89
Houston G35's Avatar
Houston G35
Everyone,
Bad or incomplete info = useless and worse yet misinformation (this hurts us all)
Good well thought out info = benefit to us all
I can certainly see how Nick may have been less than thorough at first because of his dismay at the entire ordeal. However, as this thread has developed, it seems clear that a lot of people have simply taken a defensive position for Nick.
My suggestion is to use this as an academic exercise and not be offended by questions. Please realize that most of us are sincere and really do want to learn from this situation. Can we all be adults and control our emotions. Let a open and honest flow of information continue.
Nick,
I want you to know that I am truly sorry that this happened to you. I know it was a real disappointment and financial lose. Please keep a thick skin and help us all learn. I am sure you have read many posts from GQ and Squill. As such, it is clear these guys are sincere and truly interested in learning from all valid sources.
Old Jun 19, 2004 | 02:57 AM
  #90
ACP's Avatar
ACP
Nick, you mis-understood me
I was merly trying to find out what was different from your kit, then mine (and others)
I noticed the oil pan not the same as the GReddy one I installed
Old Jun 19, 2004 | 03:40 AM
  #91
12SecZ's Avatar
12SecZ
Man,
Steve and I said the shop was legit in our city and it checked out and he is run off because of his oil pan? I drove by there today!
Good grief!
Old Jun 19, 2004 | 10:33 AM
  #92
Nick@StreetRyde
i would just like to let everyone know my frustrations.
I'm trying to post info as i get it as i don't have time to drop everything and work on the car.
the frustrating this is how everyone seems to second guess everything i have posted and treat me like a troll. i expected more from a performance community. i wqas not going to check the boards till my friend pointed out that i should post the picture of the oil pan so i will
as i said my kit seems to be the newest variation of the kit.
anyways. i'm going back to work.
Nick
Old Jun 19, 2004 | 01:09 PM
  #93
12SecZ's Avatar
12SecZ
Hey Nick,
You don't have to prove yourself here. Some apreciate your ultimimate findings when you are done. I know that small shops don't have all day to post we just like the info but feel free to take your time and fu*k the oil pan lol.
I am more interested in cylinder 5 findings, totality of damage when you break down the block specificly if it scorched the walls etc.
I suspect a lean condition with the timing being off, you are not the first and won't be the last.
Take your time, welcome to the board and let us know your findings so we can review them. Lots of us have FI concerns, I know I do!
Peas!
Old Jun 19, 2004 | 04:47 PM
  #94
derek_i's Avatar
derek_i
The oil pan interests me because if GReddy has improved the design I'd like to know. I am about to install the JWT spacer so now would be the time to switch it out.
This is my first car that I'm taking past BPU, I am in no position to question anyone else's abilities or credibility.
-D
Old Jun 19, 2004 | 06:11 PM
  #95
Sharif@Forged
Forged Performance
Yeah, Greddy has mad some improvements to the original kit.
1) The downpipes are non one piece solid....mine were were welded and slightly tapered. The newer ones are one nice piece...no welds or tapering.
2) Kenji said the new kits contain the metal wastegate gaskets, vs. the cheap paper stuff
3) I think they have improved the quality of some of the nuts, bolts, and studs...but not 100% sure.
This oil pan upgrade is new to me. Is it a higher capacity than stock? Looks like it has some heat fins as well.....curious about that.
Old Jun 20, 2004 | 04:19 AM
  #96
ACP's Avatar
ACP
-D
Me to Jeezzzz!!!
Old Jun 20, 2004 | 01:39 PM
  #97
little_rod's Avatar
little_rod
Nick, I hope we can hear more from you. I would really like to know what happened. I was afraid that you would react like that eventually, as I warned earlier. But this is a good site with good folks, so please continue to post on this topic and others.
Old Jun 20, 2004 | 06:41 PM
  #98
nightmare's Avatar
nightmare
After reading all of this Iam seriously considering not going with f/i. very scary stuff, and Iam not rich or own my own shop to be wasting my money. I dont know, we will see.
Old Jun 20, 2004 | 06:59 PM
  #99
SQUILL's Avatar
SQUILL
You shouldnt take this experience as what happens when u go F/I
Although this is what happens when your tuning is seriously wrong.
I cant see how this could happen in the hands of a competent tuner. I guess we will never know as it looks like nick is all done posting here oh well.
Runing any F/I kit has certain latent risks however with proper tuning they are very reliable you should read the hundreds of other threads on F/I setups that are running clean and generating big power !!
Use the search function... knowing what i know about F/I this thread doesnt scare me one bit i think there is no reason this motor should be toast as if the proper steps were taken it would have never happened.
Old Jun 20, 2004 | 08:03 PM
  #100
Mr B's Avatar
Mr B
Yeah, another member just bought a Greddy kit and they told me the oil pan is new. Looks pretty nice compared to what the first batch had.
I wish people would stop accusing this guy about lying. I mean, haven't you guys already bitten your tongue about the whole "YOU'RE A LIAR" ordeal? Lighten up. He already proved the blown engine. I wanna hear more about what happens to his motor and if he figures out what happened.
