woohoo toasted a motor today
Hey Mr. B...welcome to the thread after 5 pages of posts.
If you have a new kit hanging around, can you tell me if they included some longer manifold studs? The ones I had are only 6 threads deep, and the stock studs are about 11 threads deep.
One of them stripped, becuase it wasnt installed correctly.
That one, I wouldn't know. I was just told by a friend who got the new kit that the oil pan was different from the one I got. I know what you mean about the studs. I got the same damn ones and am afraid of them snapping off as more power is pulled outta my application.
A definite factor...
P.S. Sold the Kinetics Camber rods to GQ... Sorry
Cheers Amy
Hey good luck with the engine I am gonna bounce out of this FI section for awhile but I'll swing by again some day and check out what you have.
I am getting PM's about this thread, the oil pan this the engine that WTF man? My fuel pump this needs this FPR that my car runs PERFECT, I posted a video etc etc!
I see why all the old timers don't even come here anymore because of this type of BS drama.
Remember the FIRST people that jumped on board with the ATI and talked about tuning and detonation and finding timing solutions etc Eletrojug, Swinke, Mike@Altered, ZED, Jesse, Bonz, Jrit, Ravaz, GaryK and on and on it's an oil pan stop pming me man I just said the dude was legit....... This drama is like the 5th grade and you KNOW who you are peeps.....
as i scratch my head more and more and pool data from the dyno, the emanage, the peak hold readings from all the gauges.
after i had taken out 5-7 degrees of timing at wot from 4500 to redline.
after checking the peak egt of 950c
peak fuel pressure at 50 psi. (most likely dropped to 40ish at the time)
af ratio on the last dyno with a burp above 13.1
running @ 6 psi.
i surmise i did not have the BSFC (basically how much fuel you use per hp per hour.) i needed for turboed cars of .60-.65. everything calculated @ 43psi fuel pressure
Horsepower X BSFC
6 injectors X .80 (max duty cycle)
400 BHP x .65 BSFC
------------------ = 54.1 LB/HR = 560 CC/MIN
4.8
now calculating the 440s hp potential
Injector size(lb/hr) x (duty cycle)
target BSFC
440 cc/min (42 lb/hr) x .8 (max duty cycle)
---------------------------------------------------- = 51 hp per inj
.65
51 x 6 injectors = 310 HP
So i'm guessing i did not have enough fuel pressure on the rail to provide the amount of fuel needed.
Oh well time to throw in the 660cc/min and 250 lph @ 60 psi fuel pump.
what fun this has been
Nick
running @ 6 psi.
Horsepower X BSFC
400 BHP x .65 BSFC
4.8
target BSFC
.65
Nick
running @ 6 psi.
Horsepower X BSFC
400 BHP x .65 BSFC
4.8
target BSFC
.65
Nick
running @ 6 psi.
Horsepower X BSFC
400 BHP x .65 BSFC
4.8
target BSFC
.65
Nick
Even at a 100% duty cycle the greddy injectors should supply 57 hp per injector or 342 hp @ 40 psi fuel line pressure based on a bsfc of .65
it seems odd that the fuel pressure would drop that low @ 6psi.
if that is indeed what happened then of course that would cause the lean A/F ratios and ultimate destruction of ur motor however it seems unlikely the fuel pressure would drop that low.....
Strange indeed did you have anyway to measure fuel pressure?
You must have maxed out the injectors @ like 4000 rpm or something.
This is common @8 psi with most people running the greddy TT as the IDC is maxed out due to fuel line pressure limitations and lean conditions occur at the higher revs 5500 rpm and up but ive never heard of this happening @ 6 psi...
what else do you think might have happened assuming fuel system pressure was not the culprit?
So the 440cc injectors are only good for up to 310hp? What of all the other people with Greddy's kit and getting 400whp?
plus the calculations that i did not spend time doing would've saved the motor. i just have a feeling there is something not "quite" the same on the g35.
i honestly don't know any other thing other than i was unlucky. or maybe didn't pay enough attention.
expensive little mishap i guess. lol shoulda stayed with 4 bangers
i wonder how many 400whp guys have new fuel pumps.
