Oil pan... Vortech back to stock
Old Jul 8, 2004 | 10:39 PM
cwtroy's Avatar
cwtroy
Default Oil pan... Vortech back to stock
For those of you who have gone from your Vortech back to stock... what did you do about the hole in your oil pan?
Or does anyone have a guess as to how much it would cost to replace it/patch it up?
Old Jul 8, 2004 | 11:53 PM
g35twinturbo's Avatar
g35twinturbo
i have herd its just a simple hole, all u need is a piece of metal that it fits right in, if u want u can buy a new oil pan for about 200? 300?
Old Jul 8, 2004 | 11:56 PM
AmyCroft's Avatar
AmyCroft
Default NoT - These are small Tin PAns
Not - an Oil Pan is tin - Cheap..
Cheers Amy -
Performance Nissan should stock them...
cwtroy's Avatar
cwtroy
hmmm... I'm thinking it would cost a ton for the dealer or someone to install a new one...
Thoughts?
Old Jul 8, 2004 | 11:59 PM
AmyCroft's Avatar
AmyCroft
Default Do it your Self - It's quick
Thoughts?
Naw - Get a new pan and bolt it up with Honda Bond
Or Silicone - If you can't read..
Cheers Amy -
Old Jul 9, 2004 | 03:28 AM
zimbo's Avatar
zimbo
The tap is in the upper part of the pan which cannot easily be removed/replaced. You'd want to plug the hole.
--Steve
Old Jul 9, 2004 | 04:12 AM
SungNamZ's Avatar
SungNamZ
It is above the oil level. Should be able to go to a hardware store and purchase a plug with NPT threads, same size plug sent by Vortech and install with silicone sealant.
Old Jul 9, 2004 | 07:06 AM
cwtroy's Avatar
cwtroy
Well, as of now I have a plug on my car (since the install didn't go to well). But my buddy was telling me he'd worry about the plug popping out because of the oil pressure which is put on the plug.
Old Jul 9, 2004 | 07:09 AM
Forced's Avatar
Forced
The plug should be good enough. Pressure in the pan??
Old Jul 9, 2004 | 07:31 AM
cwtroy's Avatar
cwtroy
really... hmmm... do you think it'll hold if I floor the car?
He just told me that there's pressure in the pan when the car is on, so I haven't been WOT my car lately (which is good because I've had the best gas milage ever, but bad becase... well it's no fun). Anyways, Is there no air/oil pressure in the pan?
Old Jul 9, 2004 | 09:13 AM
teh215's Avatar
teh215
Get a 3/8" NPT aluminum plug from summitracing.com or a local speed shop. That will thread into the whole and won't pop out or leak provided you use thread sealant.
Old Jul 9, 2004 | 10:13 PM
cwtroy's Avatar
cwtroy
So, is there or isn't there any air pressure or any type of pressure in the oil pan? My buddy told me that there's pressure in the oil pan which helps the oil keep circulating in the engine.
Old Jul 10, 2004 | 12:19 AM
shopdog's Avatar
shopdog
Your buddy is mechanically illiterate. The only mechanism which can pressurize the oil pan is combustion leakage past the piston rings. Assuming those are in good shape, pressure in the pan is negligible. Even assuming the rings are shot, every car since 1969 has been equipped with a PVC valve to vent any pressure build up in the pan.
Engine oil is circulated in the engine by a positive displacement oil pump, and returned to the pan by gravity. Any pressure in the pan would just fight gravity, and hinder oil flow. That's why the pan is vented.
Old Jul 10, 2004 | 06:39 AM
esemes's Avatar
esemes
yep...
the CC vebts thru a line to the intake inlet tube (aka Z tube) to help keep gaseous vapors and pressure from building up .....
my question is, WHY didnt you go forward with the install?? i assume youve received the vortech kit, but didnt get further than the oil pan???
do tell!
eS
Old Jul 10, 2004 | 12:48 PM
cwtroy's Avatar
cwtroy
well, basically, we were doing the install... and stupid us (Dollar99, Me, and my "stupid friend" huducks) skipped the part where we check for the parts... bascially, vortech forgot to include some of the bolts that secure the vortech to the engine...
then after that, we went to homedepot to find some replacement bolts but none of them were the same strength... then my buddy (stupid one) broke the oil feed thing in the blower itself so we are in the process of fixing that... so baiscally we had to plug up the hole and go back to stock... anyways... we're waiting for everything to be fixed and delivered and should start and (hopefully) finish next week.
tm9293
North East Marketplace
13
Oct 17, 2015 09:14 PM
seagrasser
Oct 11, 2015 03:27 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
