Found RPM wire connection for Tach G35
Old Jul 20, 2004 | 03:52 PM
dfw350z's Avatar
dfw350z
Default Found RPM wire connection for Tach G35
I have been working with Infiniti / DynoJet for about 3 days trying to find a stable RPM connection for a Wideband Commander. Here are the places we tried to get a stable reading without success.
ECU –
Output to ignition 1-6
many more to many to list
Motor -
Ground side of coil
The last place we tried was the negative side of the # 1 Fuel Injector. It is visible below the front left side of the plenum labeled with a large (1) on the wire shroud.
This works like a champ however it’s a hard/small place to work in but does not require any disassembly of motor components. I have attached a diagram of the fuel rail and injectors for your reference. Simply tap the RED/BLACK wire and connect to your RPM device for a solid signal. I am sure others will have opinions and as everyone says “I am sure you are correct and I am wrong” this process simply worked for me after hours and hours of testing.
Old Jul 20, 2004 | 04:20 PM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
that's pretty trick... you could also grab ECU pin 21, which is where the other side of that red/black wire terminates. this way you wouldn't have to run a wire to the engine bay.
does your wideband commander need a 12v signal? that would be why the ignition output from the ECU would not work.. since it is somewhere around 5v.
good work.
m
Old Jul 20, 2004 | 04:24 PM
dfw350z's Avatar
dfw350z
good work.
m
Yea - we tried and were not successful at the ECU. It sure is nice being able to press a button and begin data logging at will along with programmable trigger wires for other cool stuff, spray etc..
Also: The red/black is a pulsing ground wire, as explained to me by Infiniti ??
Justin100
Nov 29, 2015 03:58 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
