Questions about Vortech super charger
Old Jul 31, 2004 | 12:39 PM
painkillerzz's Avatar
painkillerzz
Default Questions about Vortech super charger
I know there has probably been posts on this, but I have a few questions that may help me decide on whether or not to get this kit.
1. How much should i expect to pay for the kit. I got a quote for $4600 for the kit. Is that a good price?
2. Are there any Cons about the vortech kit, anything that may be a known problem.
3 How much should install cost on this?
4. How reliable is it? and what about maintenance, what will i have to maintain?
Any help on these questions would really be helpful.
thanks
Old Jul 31, 2004 | 12:46 PM
lorinserbenz's Avatar
lorinserbenz
Is the price for a satin or polished? If its polished then thats a good price.
Id say the only con you will hear is drilling the upper pan. It is NOT a big deal at all, if you need to sell the car you can plug the hole easily.
Install should run 1000-1500 depends on the shop, dealers will be closer to $1500.
Vortech products are VERY reliable, they have been around a long time.
There is little maintenance, when you change your oil it changes the oil in the supercharger. You need to clean the air filter from time to time and thats about it..
Go for it... you will not regret it!
Old Jul 31, 2004 | 01:26 PM
teh215's Avatar
teh215
One think to keep in mind is that if you use the stock Vortech air filter location, you will have to remove the supercharger to install a new filter. This is going to be a major PITA...
Old Jul 31, 2004 | 02:03 PM
lorinserbenz
They have new filter that is smaller and does not require removal of the supercharger. Timrod informed me of it.
Old Jul 31, 2004 | 02:06 PM
teh215's Avatar
teh215
Thanks! I'll have to give them a call.
Old Jul 31, 2004 | 02:25 PM
painkillerzz
Thanks alot guys. I do appreciate the feed back.
Old Jul 31, 2004 | 03:04 PM
esemes's Avatar
esemes
this filter installs and removes w/o any blower movement.......
the Z comes w/ a different size/shaped conical filter, taking better advantage of the space infront of the compressor (the coupe has little room whatsoever infront, whereas the Z has a window going thru the rad. support)
you can always request the filter for the coupe, if you buy the kit!!
Old Jul 31, 2004 | 04:16 PM
LOU's Avatar
LOU
I have the smaller filter as well. It is the G35 filter. It looks clean and fits a lot better than the 350Z filter.
Old Jul 31, 2004 | 06:04 PM
booger's Avatar
booger
The air filter CAN be removed with out taking off the blower . Remove the inner front wheel well [easy] Losen the clamp on the filter .Push the filter down and to the right , and it will come out easy . Clean and replace in reverse .This is for the G35.
Old Jul 31, 2004 | 06:13 PM
esemes's Avatar
esemes
boog-
for mine, i would just loosen the hoseclamp (via flathead screwdriver), and thas it...
the filter then comes off, after a few turns/tugs....
Old Aug 1, 2004 | 09:26 AM
little_rod's Avatar
little_rod
So do you just request the G35 filter in order to be able to get the filter that you can remove without removing the whole SC unit??
Old Aug 1, 2004 | 09:34 AM
esemes's Avatar
esemes
sure, i guess? (*shrugs*)....
get steve to make sure it isnt already on the Z kits now....... (should be, IMO)
S
Old Aug 1, 2004 | 10:45 PM
chaparro78's Avatar
chaparro78
Default Re: Questions about Vortech super charger
I believe that price is for the satin kit, the polished is 300 more. If you see the difference and care for look it is well worth it. I don't regret getting the pollished at all after seeing mine and then seeing the satin on another car. But it is all personal prefference.
QUOTE]Originally posted by painkillerzz
[/QUOTE]
You may hear things here and there but nothing major. There was a fuel line issue but that was due to people doing self installs and not having the propper tools. A special tool is needed when installing the fuel line and many people weren't using it, thus cause the fuel line "problem" As stated earlier you have to drill the oil pan but it is no big deal, can be plugged easilly.
[/QUOTE]
I paid 1400 which included install, tuning, dyno times, ect. Also they (Grubbs Infiniti) gave me a loaner car for the week.
[/QUOTE]
Vortech has been around for many many years. It will come with a warrenty and he only maintenace is the air filter and changing the oil regularly (in the car) this changed the oil in the SC.
Old Nov 29, 2004 | 02:03 AM
aaaaa's Avatar
aaaaa
Default Re: Re: Questions about Vortech super charger
[/QUOTE]
[/QUOTE]
[/QUOTE]
do i need to cool down like turbo timer ?
how about BOV? sounds good as turbo?
Old Nov 29, 2004 | 05:36 AM
SungNamZ's Avatar
SungNamZ
"Cool Down" is not required. I like the sound of the BOV! Some have tried various filters.
350Z_Al
Oct 29, 2020 07:44 PM
issyz
Jul 2, 2017 03:04 PM
