if my A/F is perfect.....
Old Aug 2, 2004 | 07:13 AM
zimbo's Avatar
zimbo
Yeah, your A/F is perfect, IMO. No tuner no matter how good is going to be able to significantly improve on your A/F (the blue and red lines anyway).
I think changing the timing to my suggested values will definitely help.
--Steve
Old Aug 2, 2004 | 07:16 AM
mcduck's Avatar
mcduck
tig488.... you and everyone else wants to see my maps! And I've been a slack @$$ about getting them downloaded. I promise, I'll go grab the PC connector I need this week and get the software loaded on my laptop.
I have Zimbo's number, so if I have any questions about how to get the readings, I'll give him a call. Maybe I can make this a project for the coming weekend.
Old Aug 2, 2004 | 07:21 AM
tig488's Avatar
tig488
zimbo.
you see on my pic where the A/F starts to go a little lean right around 5200 rpms, in order for me to make some adjustments for that, i should change settings at 5000 rpms right? or 5500?
mcduck.
id appreciate it, i tried one of enthuzed old maps where he got 394, on my car it only made like 350, of course he has a 350 and i have a G, it might not help, but id like to look over yours. thanks.
Old Aug 2, 2004 | 07:26 AM
zimbo's Avatar
zimbo
tig, yes you can bring down that hump at 5250 by lowering the value at 5500 on your A/F map by 0.2 or so.
One thing to keep in mind is that if you set all of the cells in a given row to the same value (i.e. the entire 5500 row is set to something like 9.1 from 0 psi to 10 psi), then you are going to see the sinusoidal pattern in your A/F plot due to the way the SS box works.
It is IMO not worth the effort required to remove the sinusoid so you will see a slight dip in A/F on the "even" numbers (i.e. 5500, 6000, etc).
--Steve
Old Aug 2, 2004 | 07:28 AM
zimbo's Avatar
zimbo
Another thing to remember is that mcduck is going to be burning a lot more fuel due to all of the perf mods he has installed. His map is likely to be too rich for you (as mine was).
--Steve
Old Aug 2, 2004 | 08:28 AM
tig488's Avatar
tig488
would a TS reflash help me at all, other than raises the redline, you think they might be able to smooth the curve.
Old Aug 2, 2004 | 12:44 PM
zimbo's Avatar
zimbo
Other than the raised redline, NO it wouldn't help your existing curve IMO.
--Steve
FromGtoZ
Sep 20, 2015 03:41 PM
ATI ProCharger
Mar 9, 2004 07:30 AM
jesseenglish
Dec 15, 2003 06:40 AM
Slexis200
Aug 20, 2002 04:46 AM
