Vortech Belt Slip/noise Solution
Old Nov 5, 2007 | 02:02 PM
  #41
booger's Avatar
booger
Like I said...get the GTM pulley..it will work best .
Old Nov 5, 2007 | 02:09 PM
  #42
sentry65's Avatar
sentry65
the burninator
I'd try the GTM method first too since it's a lot less hassle
Old Nov 5, 2007 | 02:50 PM
  #43
Mr_pharmD's Avatar
Mr_pharmD
Originally Posted by Everybodywildou
bump. I'm also curious what need to be done to the bolt.
the belt will touch the bolt if u dont either get a new bolt or mill it down.
Old Jan 30, 2014 | 11:28 AM
  #44
Z33Garage's Avatar
Z33Garage
Sorry this one??
http://www.gtmotorsports.com/product...cat=472&page=1
Old Dec 20, 2017 | 04:41 PM
  #45
rottingcat's Avatar
rottingcat
I’m in the process of doing this and you also have to get the walls (sides) of the OEM pulley slightly lathed down since the top/flat side of the belt is slightly larger in width than the grooved side. The walls of the OEM pulley are champhered for the original belt layout that’s why. Will update you guys later
Old Dec 20, 2017 | 04:50 PM
  #46
rottingcat's Avatar
rottingcat
pics of lathed down pulley
Old Jan 17, 2018 | 09:43 AM
  #47
rottingcat's Avatar
rottingcat
had the bolt grinded down .2 of an inch....um will this hold can i even put a socket on it to torque it???
Old Jan 17, 2018 | 10:25 AM
  #48
rottingcat's Avatar
rottingcat
FOR THOSE WHO ARE FOLLOWING THIS BELT LAYOUT AND HAVE THE 2.87 PULLEY
Apparently the length and p/n of the gates belt is incorrect and too long. Sentry said that he used this p/n in this post.
https://my350z.com/forum/forced-indu...ml#post3492634
Will update again if belt size is correct
UPDATE: Sentry runs an extra idler pulley in his setup so I would go with OldManZ350's in his post below.
Old Jan 17, 2018 | 11:21 AM
  #49
OldManZ350's Avatar
OldManZ350
YES, the Belt Length is Wrong in Original Post.
My Belt is 91-1/4” Long with a 2.87 Pulley.
Napa/Gates Micro-V 060908
The old info was the Belt I started out with....
And BTW, this Thread I started 14 years ago.......
Old Jan 17, 2018 | 11:37 AM
  #50
OldManZ350's Avatar
OldManZ350
machine (or grind) the Head Hight down to about .200 in.
Head should be about .200" Thick
It Does Not say remove .200"
Old Jan 17, 2018 | 12:55 PM
  #51
rottingcat's Avatar
rottingcat
Im so dumb. Thank you for clarifying! And thank you for updating OP. Everyone says to search the forums for answers, but sometimes 14 year old threads are out of date haha.
Old Jan 17, 2018 | 01:12 PM
  #52
OldManZ350's Avatar
OldManZ350
No big deal, you just read it incorrect..... and maybe it was not that clear.
Old Jan 17, 2018 | 01:22 PM
  #53
rottingcat's Avatar
rottingcat
Oh and another side note:
OldManZ350's part number for the belt 060908, also comes in a P/N K060908HD
HD = The belt is green, is according to gates it is a more heavy duty construction.
http://www.hellcat.org/threads/green...s-belts.41209/
Cheapest I could find in 2018: (Or Ebay which is like $0.10 more lol)
https://autoplicity.com/3177470-gate...hoCYf0QAvD_BwE
Old Mar 13, 2018 | 11:55 AM
  #54
BluestreamDE's Avatar
BluestreamDE
Thank for sharing that!
Uriyo_
Sep 8, 2021 08:46 AM
350Z_Al
Oct 29, 2020 07:44 PM
Fixxxercask
Nov 9, 2015 11:10 AM
Calinismo350z
Sep 14, 2015 04:04 PM
