Profec AUTO mode--PlEaSe HeLp!?!
Old Oct 31, 2004 | 01:12 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
Default Profec AUTO mode--PlEaSe HeLp!?!
so... i can't seem to switch my profec-e01 to auto mode at 6lbs of boost... i follow the setup instructions... as far as the settings, then WOT in 3rd gear 3-4 times... but the entire time the auto icon blinks, it doesnt register the setting, and it only runs 4.5 lbs.. so in the meantime i'm back on the manual mode and running 6lbs no problem...but would like to keep it on auto
ANY SUGGESTIONS???
Old Oct 31, 2004 | 07:17 AM
7 eleven's Avatar
7 eleven
What is your gain set at? It sounds like it is to low. Try increasing it a little at at time.
Gary
Old Oct 31, 2004 | 08:56 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
when setting on auto mode, i set it at:
boost: 6
gain: 10
start: 5
manual mode to get 6lbs:
set: 30%
gain: 12
start: .5
What do you think?????
THANKS
Old Oct 31, 2004 | 09:06 AM
7 eleven's Avatar
7 eleven
Try setting Gain to 15. If that doesn't do add 2 to the gain till you get there. Just take it slow and watch the boost. Start should be 2.8 psi less than what target is.
Gary
Old Oct 31, 2004 | 09:46 AM
350zDCalb's Avatar
350zDCalb
builtZmotors
ok ill try it out
thanks
Old Oct 31, 2004 | 07:02 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
350zDcalb....30% in the manual mode is much too much. That will easiliy take you to 7psi or more...depending on the gear.
Try increasing the gain...and keep doing the WOT runs until the program light stops flashing. It may look like you never hit your target, but once its learned, it gets really darn close.
Old Oct 31, 2004 | 07:56 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
gq: i've watched it closley, its never gone above 5.9 lbs in the manual setting even at 30%...
could the altitude dampen this a little bit?
Old Oct 31, 2004 | 08:06 PM
350zDCalb's Avatar
350zDCalb
builtZmotors
also gq:
i did the WOT several times... the auto continues to blink aimlessly
am i missing something????
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
bcoffee20
Nov 19, 2015 06:39 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
jlc280z
Sep 24, 2015 08:43 AM
