Sts Turbo
Old Nov 22, 2004 | 01:06 PM
1G''s Avatar
1G'
Default Sts Turbo
I really hope they make one for the 350Z!!!
there are so many plus's to this that it's crazy!!
I know this maybe to radical an idea for some but trust me it works and it works very well.
Old Nov 22, 2004 | 01:13 PM
G3po's Avatar
G3po
Default Re: Sts Turbo
Works well huh? no spool time there , LMAO...
Old Nov 22, 2004 | 01:16 PM
teh215's Avatar
teh215
Good thing that the filter is easy to get to because you're going to be changing it like you change underwear. Not to mention road debris taking out the turbo from time to time.
Old Nov 22, 2004 | 01:17 PM
JeffR116's Avatar
JeffR116
Interesting....
It'd be extremely easy to work on, but good luck on driving it in the rain with that filter sitting under the bumper
Old Nov 22, 2004 | 01:36 PM
1G''s Avatar
1G'
Default Re: Re: Sts Turbo
nope that was the first thing they tackled
Old Nov 22, 2004 | 02:14 PM
protocav's Avatar
protocav
that is an extremely innovative idea!! if they can handle turbo lag (perhaps with the use of very small diameter intercooler piping, then it just might work.
i agree that the filter should be shielded from the environment, as well as the turbos. if the turbo is running really hot, and you get a big splash of hot water on there...you might be in trouble.
Chad
Old Nov 22, 2004 | 02:21 PM
MIAPLAYA's Avatar
MIAPLAYA
Chad
Old Nov 22, 2004 | 03:15 PM
axxizzer's Avatar
axxizzer
that design, from an engineering point of view
SUCKS
it will be warped from rapid temp change, blasted by debris, and you probably have to replace the filter daily
not to mention, by the time it spools at all, you will already be done with the race/getting groceries/auto-x
unless its on a 911, then the engine is like...right there
Enron Exec's Avatar
Enron Exec
The exhaust gas leaving the engine has to travel almost the whole car length to spin the turbo and then the compressed air has to travel another car length back to the intercooler and then into the engine. I see alot of problems here.
Old Nov 22, 2004 | 03:16 PM
axxizzer's Avatar
axxizzer
whoa, same minute
Old Nov 22, 2004 | 03:17 PM
Enron Exec's Avatar
Enron Exec
Originally posted by axxizzer
whoa, same minute
Im watching you...
Old Nov 22, 2004 | 03:21 PM
axxizzer's Avatar
axxizzer
what do i have my hand on right now
indrid cold?
Old Nov 22, 2004 | 03:27 PM
hndumafia's Avatar
hndumafia
i remember a friend talking about these being used on mustangs and stuff and that they actually worked well. i dont actually know anything about this type of turbo kit myself though.
Old Nov 22, 2004 | 03:34 PM
axxizzer's Avatar
axxizzer
sure they work well, till you go over a speed bump or tire traps
Old Nov 22, 2004 | 03:37 PM
axxizzer's Avatar
axxizzer
WTF
when did my...thing that said regular turn into KNow it all
although it is very suiting
Old Nov 22, 2004 | 05:52 PM
350G's Avatar
350G
I was always under the impression that you wanted the turbo as close as possible to the engine to take advantage of the heat to spool it. In either case, it could aid in traction issues since it won't be spooled until you're well beyond 40mph
Old Nov 22, 2004 | 06:43 PM
phunk's Avatar
phunk
CJ Motorsports
large displacement engines dont need the spoolup like smaller ones do.
but either way, that **** is wack.
Old Nov 22, 2004 | 06:48 PM
silverstone_04's Avatar
silverstone_04
actually this set up work great, there is a local camaro with one and it was nasty....
and the guy who owns the shop that did the install has a 280zx and is planning on doing it to his car...
Old Nov 22, 2004 | 06:55 PM
axxizzer's Avatar
axxizzer
what if you hit like a rock
what then?
thousands of dollars of damage
Old Nov 22, 2004 | 08:00 PM
phunk's Avatar
phunk
CJ Motorsports
its interesting how people say it works "great"
without comparison to a convential turbo in the engine bay system... all i would think you can really say is "it works".
people are to quick to say it works "Great" simply because it makes power... but IMHO "great" should be reserved for something proven efficient maybe or what not.
so the question is does it really work GREAT or does it simply just WORK?
-charles
