limited slip diff
Old Jul 19, 2005 | 05:40 PM
Dan03Sedan's Avatar
Dan03Sedan
Default limited slip diff
Has anyone tried to replace the standard differential in an auto sedan with one of the limited slip units from a 6 speed???
Old Aug 3, 2005 | 07:33 AM
AznIceRckt's Avatar
AznIceRckt
i believe you need the 3.5 ring and pinion and it should work.
Old Aug 3, 2005 | 06:58 PM
snolden's Avatar
snolden
I have one already. I am still gettin round to it. make me an offer at seannolden@frontiernet.net
I am still debating whether to install it or by the kaaz clutch type lsd
Old Aug 3, 2005 | 08:06 PM
Gsedan35's Avatar
Gsedan35
That is correct and it's not all.
In order to install a M/T viscous core into a A/T open diff not only to you have to purchase the ring and pinion gearset for a M/T diff which will run $500, but you also must purchase new $150 each LSD stub axles as your open diff stub axles cannot be used. Add in the $400 cost for the labor to have it done, and your looking at a very high price. Buying a used sealed pumkin with everything already installed makes the most sense, since you can now locate them pretty readily and for around $500.
I did a oem VLSD swap using a viscous core that had showroom floor miles on it. Even though I only paid $100 to buy the core, the cost of the LSD axles and the cost of labor ment I ended up spending $900 when I was done, given the lackluster performance of the oem VLSD, I might as well had stuffed $900 in a shoe box and buried it in my backyard. And I don't even track my car.
Old Aug 6, 2005 | 02:37 PM
Binictican's Avatar
Binictican
Default WOw
Sorry to hear it didn't work out as well as expected. Good info though.
Better to just get a 3.5 FD for my AT.
Old Aug 6, 2005 | 08:44 PM
StarcraftBW's Avatar
StarcraftBW
dont' get the SLIP diff......i have to turn if off everything i am driving my car .....
loudtoyz
Apr 6, 2023 04:52 AM
aarrgghh
May 1, 2022 11:04 AM
Glenn350zHR
Drivetrain
Nov 30, 2015 08:21 AM
Boots patrol
Exterior
Nov 7, 2015 12:26 PM
