Can i use stock 350Z springs on a 2006 G35 to lower it?
Old Jun 22, 2006 | 04:25 AM
Gurveer's Avatar
Gurveer
Default Can i use stock 350Z springs on a 2006 G35 to lower it?
hey guys i have an 06 G35 coupe 6mt and i believe i read something about being able to use stock 350Z springs to lower the G35
is this true?
thanks in advance
Gurveer
Old Jun 26, 2006 | 12:46 PM
wnt1bd's Avatar
wnt1bd
ummmm.....I believe that since you already have the 6MT you already have the same springs as the Z? I could be wrong, but yes watch your rates. 427's in the rear is a tight spring, most "lowering springs" for the G are a softer rate, that means your handleing will get screwed.
Old Jun 26, 2006 | 04:23 PM
andy2434's Avatar
andy2434
I got a set of '06 Z springs from a member here. The newer revised Z springs match my existing rear spring rate of 427 exactly. The Z Tein H-Techs, which I had originally got are much softer. They are 356 Ft and 375 Rr. I will not get the same drop from the Z springs, but I'll preserve my existing ride quality.
Old Jun 30, 2006 | 01:50 PM
Rookie84's Avatar
Rookie84
Huh? Lower springs rates = softer ride... Well, maybe the springs didn't match your shocks well... hmm... I'm gonna use Z H-techs with revised Z shocks so hopefully I won't have any problem with the ride. I would imagine not with a minor drop like that in spring rates.
m_0g
Jun 3, 2021 10:05 AM
James1990
Dec 16, 2015 08:57 PM
Paul.
Oct 16, 2015 07:34 PM
nissan1310
Oct 12, 2015 08:54 AM
CJs_Z33
Sep 18, 2015 12:06 PM
