G35 vs 5.0 Mustang????
Old Aug 26, 2006 | 05:31 PM
rlwjr1's Avatar
rlwjr1
Default G35 vs 5.0 Mustang????
My friend has a Ford Motorsport sticker across his windshield. He swears that before and after times at the track were 0.15 sec and about 5 mph. This is because the raised lettering creates a boundry layer over the windshield and roof area making the car more aerodynamic.
He also painted his car white which gained him 0.08 sec and 2.53 mph. The reason being that white has less pigment and thus is lighter weight.
Question, if I put a Nismo sticker on BOTH my front and rear glass will I gain the required 25 rwhp needed to beat him???
If I just chemically strip my paint off and paint the bare metal with clear would my car get under 2300lbs????
Old Aug 27, 2006 | 07:01 PM
Billinohio's Avatar
Billinohio
your kidding right? I thought those windshield stickers went on the inside and the little painting I did, it only took about 2 quarts for a car.
Old Aug 27, 2006 | 07:09 PM
I knew that sometime was not right with you G35 guys. Now I have irrefutable evidence.
Old Aug 27, 2006 | 07:21 PM
CEO350Z's Avatar
CEO350Z
That's bad juju
if he adds a sticker graphics kit across the body of the car, it's the equiv. of getting a rousch supercharger!!! heck, if he strips the paint and just put on a layer of clearcoat, he has himself a 9sec car!!!!
Old Aug 27, 2006 | 07:28 PM
mikealexander's Avatar
mikealexander
what are you beign serious, remember it says in your profile you are a mechanic dont tell me you are beign for real iam a tech at toyota and if you said that **** in the shop nobody would ever ever stop making fun of you cmon dude think
Old Aug 27, 2006 | 11:45 PM
imalazeeass's Avatar
imalazeeass
you guys arent seriously taking this guy seriously right?
Old Aug 28, 2006 | 09:16 AM
rlwjr1's Avatar
rlwjr1
Old Aug 28, 2006 | 10:28 AM
ATL_Red_G35's Avatar
ATL_Red_G35
I say go for it.
Here are what I did as well:
I also have stickers at the bottom of the car and it shaves off 0.78 of a second because the air flows through a lot smotther and thus create just about the right lift for the car.
I also put a string accross each of the exhaust tip. It splits the air flow and halves and thus double the thrust. Saved me another 0.21 second.
I too popped the hood but didn't lift it up so it can channel enought ram air to cool the engine bay at high mph.
I lowered my windows to about 28.761% open so that enough air will get it and lift the car up a bit to reduce wiehgt without causing any drag in the winds at all. I think that helped save about a whole 800lbs of the dragged weight of the car.
G'luck.
Oh, and remember to use those heavy duty aircraft remover to remove the paint. They really did me a good job. I made it into high 11s with these simple mods.
Good luck and play it cool
Old Aug 29, 2006 | 12:15 PM
momo 350z's Avatar
momo 350z
Old Aug 29, 2006 | 06:06 PM
imalazeeass
u would have better results if u lowered ur window to 18.6% instead of 28.761
Old Aug 30, 2006 | 05:09 AM
ATL_Red_G35
I tried 18.6% and it didn't lift it enough. the 28.761% will have a lil more drag, but at the same time, weight will be dramatically reduced so the Drag to Weight ratio is slightly better.
Old Aug 30, 2006 | 05:16 AM
GSXR-Z's Avatar
GSXR-Z
I shaved off a full 3 seconds and put 431 hp to the wheels on a dyno by removing the engine and tranny. Did you know that they add 700 lbs?? Thats a lot of weight!
Old Aug 30, 2006 | 09:24 PM
RobertH's Avatar
RobertH
well i got smart an ordered 3 turbonator's. you wont believe the difference between 2 and 3 turbonator's
Old Sep 2, 2006 | 09:23 AM
LayinLo's Avatar
LayinLo
You guys are hilarious!!!!!
Old Sep 7, 2006 | 07:04 AM
OU812G350's Avatar
OU812G350
If U Add Up Hp And Torque #s For Products U Can Buy For Our Cars We Would All Have 500 Hp 550 Tq Vehicles That Run On Pump Gas And Get 30mpg At The Same Time Running 11.20 In The 1320.............
Old Sep 7, 2006 | 07:23 AM
350z0827's Avatar
350z0827
hey now a 5.0 mustang is no joke, I had a 91 5.0 mustang notch back ran 14.8's bone stock. I removed the 5.0 emblem and replaced them with cobra's, put saleen decals all over it and installed a saleen wing. Never go to take it back to the track but it felt like I would run at least 8's in the quarter. It was insane after the saleen stuff and cobra emblems. I tried putting cobra emblems on my Z but didnt have the desired effect, was much faster with the cobra emblems but the overall handling went to crap.
Just kidding
Old Sep 8, 2006 | 09:20 AM
NIzzanturboka's Avatar
NIzzanturboka
gn
Old Sep 8, 2006 | 06:00 PM
rlwjr1's Avatar
rlwjr1
You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is single input O-Pipe with polished finish.
Wish you had a little more low end torque? Maybe you want a high revving formula1-esque screamer? KaleCoAuto's Adjustable Powerbands are the perfect solution! The power bands are made from titanium-injected rubber, with high grade 440 fasteners. Six links are included. One band is for horsepower, and the other for torque. You may use more than three links per side, but extreme caution should be taken!
Old Sep 11, 2006 | 03:08 AM
SteveZ's Avatar
SteveZ
Yes, but will it get me my 10 second car? Someone owes me a 10 second car!
(speak using Vin Diesel voice)
JjL
East Canada
Jun 12, 2019 03:04 AM
kyin
Oct 15, 2015 05:54 AM
seagrasser
Oct 11, 2015 03:27 PM
Alexreyes
Sep 30, 2015 11:30 PM
