OS Giken TR2A G37 Clutch Install
Old Oct 5, 2011 | 09:25 AM
JE's Avatar
JE
Vendor - Former Vendor
Default OS Giken TR2A G37 Clutch Install
What's up guys? Being one of OS Giken's largest retail distributors on the east coast, we have the oppertunity to install and test out many of their products on all applications. We recently had a 2009 Infiniti G37S come in the shop for an OS Giken TR2A Clutch install. This clutch kit includes a smaller style twin disk setup that can handle upwards of ~500whp . These clutches are the latest technology in racing drivetrain applications. PM or Call me today for exclusive VQ pricing.
Transmission is out and clutch is ready to be installed
OS Giken highly recommends upgrading the slave cylinder sleeve assembly to be able to handle the increased pressure and power capacity.
Let me know if you guys have any questions reguarding availability or fitment. We can special order any OS Giken product for any application. Thanks for looking.
Old Oct 5, 2011 | 11:56 AM
AngelsVQ's Avatar
AngelsVQ
nice
Old Dec 27, 2011 | 05:39 PM
ZSpeedPerformance's Avatar
ZSpeedPerformance
That's a nice looking HD Clutch Slave
Old Jun 4, 2012 | 05:46 PM
g37sportdriver's Avatar
g37sportdriver
hi my name is shawn and i bought a 08 g37 sport about a month ago and a week after i got it the clutch went out. i pulled the tranny and put a spec clutch and flywheel in then put it all back together and for some reason my car cranks but wont start do u have any idea what i could of done wrong/
Old Jun 4, 2012 | 06:08 PM
ZSpeedPerformance
Did you install the flywheel in the correct clocked position?
Old Jan 2, 2013 | 11:16 PM
noKio1R's Avatar
noKio1R
I purchased a set from Zspeed for my '08 350Z Nismo V.(US Spec.) the OSG STR2CD, with the Wilwood MC, and HD CSC, what other things do I need to make this install work properly. Do I also need performance fluid? My OSG kit didn't come with a bearing, so I'm feeling a bit skeptical on doing the install, until I could find another way of putting this kit in my car.
Old Jan 2, 2013 | 11:24 PM
noKio1R's Avatar
noKio1R
I have a 2008 350Z Nismo V. (US Spec).
I purchased a kit from Zspeedperformance, as I recalled when I spoke to Joe, about my purchase. o bought the OSG STR2CD, Wilwood MC, and the HD CSC, my question is, what other things do I need other than the tools in my garage to make this function in my car, when changing out my clutch, with this setup?
Old Jan 3, 2013 | 12:06 AM
noKio1R's Avatar
noKio1R
does this site even have a "How to?" on certain products, especially on OSG clutch kits; such as the STR2CD, or one must be mechanically inclined?
Old Jan 3, 2013 | 08:16 AM
ZSpeedPerformance
You should not need anything else except trans fluid, We use and recommend Motul gear 300 trans fluid. You will also need a 1/2 pint or pint of fresh DOT 3 brake fluid for the hydraulics.
Old Jan 3, 2013 | 08:18 AM
ZSpeedPerformance
It is fairly involved to change, If you are not comfortable with changing a clutch/flywheel and bleeding a hydraulic system I would look for someone qualified to install it all for you.
Old Apr 6, 2013 | 09:49 PM
noKio1R's Avatar
noKio1R
I'm wondering how much more bleeding must be done in order to get that stiff feeling on the pedal? or do I still have air inside the steel lines from the Wilwood MC and the HD CSC?
Old Apr 7, 2013 | 11:55 AM
ZSpeedPerformance
How stiff the pedal feels is all related to the clutch itself. Its not something you can change by bleeding.
The STR2CD clutch will have a pretty light pedal feel.
Stevo Z
Oct 3, 2015 09:14 PM
