Engine swapped? 289k miles
Old Jul 16, 2022 | 07:43 PM
nonutz's Avatar
nonutz
Default Engine swapped? 289k miles
So as the title kind of says I think my car's engine's been swapped recently purchased a 2003 G35 sedan.
Old owner had a title pawn on it and was going to lose the car so instead sold it to me for dirt cheap car runs great transmission is smoooooooth.
Decided to put it under the knife like I did my old 350z and while doing headers noticed oil from valve cover. The seals are bad.
So to get straight to the point I took my valve covers off and it's extremely clean inside.
I've noticed the whole block is spotless only a few signes of wear but no burn oil on any parts of it. Buckets are not really scratched. No brown anywhere from old oil. I was wondering if anyone has stripped a vq35de engine and how nasty the heads where? Here is a pic to show you how clean a supposed 289k mile car is.
Old Jul 18, 2022 | 05:52 PM
nonutz's Avatar
nonutz
Bump.
if you look at the timing cover and the heads the heads are extremely clean and the timing cover is nasty. The block looks clean everything but the timing cover. I mean the thing has 289k miles.... It's a 2003 idk 😐
Old Jul 31, 2022 | 03:57 AM
nonutz's Avatar
nonutz
Bump still no answer.
took some pics of inside the timing cover. I'm starting to bleave this engine is new.... Oil pump looks shiny. The inside of the valve cover looks amazing. So idk can someone chime in?
Old Nov 23, 2024 | 02:58 AM
newiron008's Avatar
newiron008
If your planning on keeping it around for a while would be better to look into a remanufactured engine if new is to pricey at the moment but the only effect in pitting a older engine in would be sell value and anything else that comes with a higher milage engine
Old Nov 23, 2024 | 07:53 AM
travlee's Avatar
travlee
Master
2 years late on this one also
Siciliang35
Jul 9, 2016 10:16 PM
allmycarsdie
May 13, 2016 04:38 PM
NOLAGG
Oct 13, 2014 09:24 PM
Doc_Z
Feb 6, 2010 08:24 PM
sobceo
Jul 10, 2008 05:59 PM
