Engine Ticking Like It Needs Oil! But It Doest!
Old Jun 17, 2008 | 02:49 PM
sobceo's Avatar
sobceo
Default Engine Ticking Like It Needs Oil! But It Doest!
I have changed my oil at regular intervals since i had the car with Synthetic... But for the last few weeks my engine has been ticking very loudly and seems to be getting louder. It ticks at the speed the engine is going. Someone suggested that it may have lost compression??? Has anyone else had this problem and if so how much did Nissan charge?? Someone also suggested a tuneup but i dont see how a routine tuneup would take care of this problem.
Old Jun 17, 2008 | 02:52 PM
sobceo's Avatar
sobceo
BTW Its a 2003 with about 80k miles on it. Thanks.
Old Jun 17, 2008 | 03:46 PM
And the tapping sound is more noisy when the motor is warm?
a. Improper valve clearance
b. Motor oil is low
c. Low oil pressure
d. Valve lifters are worn
e. Connecting rods are bent or worn
Old Jun 17, 2008 | 04:52 PM
sobceo's Avatar
sobceo
I would say its just as loud warm or cold.... Does this help define what the problem is??
BTW.. That stuff you named sounds hellva expensive...
Old Jun 17, 2008 | 05:20 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
lifters are out of adjustment most likely or the oil passages to them are clogged.
Old Jun 17, 2008 | 05:58 PM
sobceo's Avatar
sobceo
Hmm this definitely sounds plausable. About on average how much is something like this at the dealer??? Thanks.
Old Jun 17, 2008 | 06:00 PM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
what changing the lifter? ALOT!!!!!! id try to run cleaner through your system first and see where that got you.
Old Jun 17, 2008 | 06:04 PM
sobceo's Avatar
sobceo
I put in some oil cleaner about a 3 weeks ago during oild change and since then it has gotten louder.. So not sure if thats going to help. Maybe I will try and change again and add something.. What do you recommend??
Old Jun 19, 2008 | 09:36 PM
red350track's Avatar
red350track
i would add some of this, it worked on my 300zx with the lifter tick and i dont see why it wont work with the 350z http://www.lucasoil.com/products/dis...tid=2&loc=show
Old Jul 9, 2008 | 11:15 PM
stealthz's Avatar
stealthz
yea a bad rod bearing would be a bummer... It would be cheaper to get a used motor if thats the case...Do you run your car hard?
Old Jul 10, 2008 | 05:59 PM
R-TuneZ's Avatar
R-TuneZ
i would say its probably a valve train issue. i need some more information to work with though, is your oil pressure normal? what are the specs after the engine is warmed up and what weight of oil are you using? synthetic? is the ticking audible within the passenger compartment, and if so, at what rpms?
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
Fixxxercask
Nov 9, 2015 11:10 AM
