Wire harness wire question.
Old Jul 18, 2022 | 05:48 PM
nonutz's Avatar
nonutz
Default Wire harness wire question.
So I'm cleaning up my harness doing a wire tuck and I have a issue with this black wire gray stripe that goes on to the coil packs my question is is this just a ground/- wire it attackes to the front of the engine at the back timing cover with a loop. If this is just - or ground then I can probly cut it and ground it on the back side of the block vs it sitting in the front looking all thug nasty. Re routing my harness to the back of the block vs. that thick ugly thing in the front trying to make a clean engine bay without all the crazy wires everywhere.
Old Jul 18, 2022 | 08:19 PM
bealljk's Avatar
bealljk
The coils can get very finicky - if it was me, I’d keep everything exactly how it is and reconnect to the backside of the block out of sight.
Old Jul 18, 2022 | 08:21 PM
nonutz's Avatar
nonutz
Well **** was hoping I could wire solder it like IV done with computers and use a shrink wrap. I guess I can just try it and worse case I know where I fugged up at lol.
Old Jul 18, 2022 | 08:24 PM
bealljk's Avatar
bealljk
I wouldnt use solder either…
an old coworker / mentor used to say ‘you know how you keep a hard-on? You dont f’ck with it’ …
Old Jul 18, 2022 | 08:26 PM
nonutz's Avatar
nonutz
Damn damn I need to figure out to route the coil mess then. The rest looks great until those coils the **** is a whole bunch of wires all soldered together every which way lol
Old Jul 19, 2022 | 06:31 AM
bealljk's Avatar
bealljk
It’s goofy … I seperated all my wires into single runs, wrapped each, and left the coils alone. I was able to run the coils behind the plenum without stressing the wires.
If you need further help let me know … happy to help!
Old Jul 19, 2022 | 07:47 AM
nonutz's Avatar
nonutz
You know the only question I have is what did you put your ground wire to?? Like the one that's usually in the from on the timing cover? It's a loop thing that's on the coil wires with a black a gray stripe wire.
Old Jul 19, 2022 | 11:38 AM
bealljk's Avatar
bealljk
I just put it on a 10mm bolt on the back of the plenum
Old Jul 19, 2022 | 11:40 AM
nonutz's Avatar
nonutz
So pretty much treat it like the wife and find a hole to stick it in. Make sure it's grounded to the engine. I wouldn't do the platinum as I got a kinetics. But I can do the block somewhere.
crsracing19
Southern California
Jan 15, 2014 09:54 AM
absurdparadox
Mar 20, 2011 09:25 PM
MRfire
Mar 18, 2010 06:22 PM
dingobiatch
Jan 27, 2009 04:16 PM
Voboy
Jun 3, 2006 09:26 PM
