installed Hawk HPS pads today and.........
Old Apr 26, 2004 | 03:26 PM
esemes's Avatar
esemes
Default installed Hawk HPS pads today and.........
absolutely
NO
dust
after 20 miles of bed-in driving....... (had more dust driving 1.2 miles from my house to the dealer today)...
INITIAL BITE = bests the oem brembo pads..... ALOT.....
here's my issue.... the front pads were actually 0.06 bigger than the oem pads..... they actually wouldnt fit in the calipers... without force...
so they shaved about 0.04 off of eacj side, to give a little play...
but now... they clank when i go from a reverse braking to a forward braking....
its not too bad, and the cleanliness of em is well worth it, BUT, i am wondering, if anyone else has this fitment issue....
help?!?!
Old Apr 26, 2004 | 03:51 PM
jpc350's Avatar
jpc350
Default Re: installed Hawk HPS pads today and.........
Originally posted by esemes
absolutely
NO
dust
I changed mine to HAWK HPS and no problem with the instal into the calipers.
help?!?!
Old Apr 26, 2004 | 04:59 PM
JonathanG35's Avatar
JonathanG35
Default Re: Re: installed Hawk HPS pads today and.........
Originally posted by jpc350
i had no fitment issues. mine squeal but i have little to no dust after 1000's of miles
Old Apr 26, 2004 | 05:02 PM
esemes's Avatar
esemes
Default Re: Re: Re: installed Hawk HPS pads today and.........
j-
so you just slid the pads into the calipers, without any resistence??? it wasnt a tight fit at all??
please advise
thanks
Old Apr 26, 2004 | 05:07 PM
JonathanG35
Default Re: Re: Re: Re: installed Hawk HPS pads today and.........
j-
please advise
thanks
I had no problems but i think some others have. check the wheels tires brakes suspension section . this was the last place i saw anything about fit issues, or try a search for hawk fitment.
jon
Old Apr 26, 2004 | 05:53 PM
esemes's Avatar
esemes
searched alot
read alot
i still havent found what i am having...
a pronounced 'clack' when cheanging directins (for to rev, and vice versa) is heard and felt in the calipers...
like the pads are actually moving
how can they, when the positioning rods run thru them (in two places even)
go##ammit!! i am frustrated!!
-eS
ps- borla for sale
Old Apr 26, 2004 | 06:01 PM
JonathanG35
post your problem in the wheels tires etc section. I read exactly what you are talking about in a thread there about 3-4 weeks ago. I am sure the same people will pop up to help. You will get a wider audience that way.
luck,
jon
-count your blessings, i need a new tranny!!!
Old Apr 26, 2004 | 06:16 PM
2003z's Avatar
2003z
mine didnt make clacking noise, but I had to shave one corner of one hps pad for them to fit the brembos and had to shave about 1/16" off of each front pad when I put hp+ in.
Old May 3, 2004 | 07:15 AM
D_Nyholm's Avatar
D_Nyholm
I had to shave a little off of each of the front pads (the mounting plate, not the pad material itself) to make it fit. I haven't had any squealing problems with the fronts, but the rears do get a little noisy when they get hot...only on random days though!!!
I noticed that the pads dusted almost as much as the stock pads for the first 100 or so miles, now they are pretty clean.
Old May 3, 2004 | 07:28 AM
esemes's Avatar
esemes
so no clanking noise, like the pads are shifting a bit?? (when you change directions and apply the brakes??)
Old May 3, 2004 | 07:51 AM
D_Nyholm's Avatar
D_Nyholm
Nope, sorry, none at all. They are much quieter than the stockers....
Old May 6, 2004 | 08:05 AM
esemes's Avatar
esemes
fixed the clanks!!
i got ANOTHER set of front pads, and this time tapped them into the calipers (they fit way better than the first set).....
also, i had the oem brembo shims applied to the pad plates, with antisqueal compound.....
silent, clean, and stops even better.......... (no shifting of the pads anymore!!)
FINAL NOTE on the HAWK HPS pads:::::
DO NOT SHAVE THE PAD PLATE/BACKINGS....... just take your time and tap them into the caliper body w/ a rubber mallet (or the like)
if you grind them, they can/will shift around a little in the caliper (enough to drive me nuts!!)
happy ending indeed
-eS
Old May 6, 2004 | 11:04 AM
D_Nyholm's Avatar
D_Nyholm
I guess I didn't shave them down that much. They were still difficult to squeeze in there after they were shaved, so I must have not taken off that much material.
I do have a problem with the rears though. They squeal like crazy when they get warm. Not HOT, just warm. I did one quick stop from 110 to 40 and then they started squealing like crazy until they cooled down.
Old May 6, 2004 | 11:12 AM
esemes's Avatar
esemes
did you use the anti squeal stuff??? this should help the noise......
Old May 6, 2004 | 01:54 PM
D_Nyholm's Avatar
D_Nyholm
Yeah, i used A LOT of anti squeal. The fronts are completely fine but the rears make all the noise. I think I am going ot disassemble the rears and put the anti squeal on it and let it dry a little longer to tack up better and make a better block for the noise.
I also tried bedding them a few times to no avail. Has no one else had a problem with the rears???
Old May 7, 2004 | 07:07 AM
esemes's Avatar
esemes
you installed the oem shims too??? his might be the answer!! (hope)
Old May 7, 2004 | 11:26 AM
D_Nyholm's Avatar
D_Nyholm
I actually didn't install the shims. I have never installed shims on my other cars and they seemed to work fine. Where would I get the shims? They didn't come with the Hawk pads. That might be a nice idea if that fixes it!!! Thanks for the suggestion!
Old May 7, 2004 | 11:46 AM
esemes's Avatar
esemes
TRY IT!!
i used my brembo shims (peel em off with a puddy knife, or blade screwdriver......
this made ALL the difference for me, as mine were aweful (at first) too.........
let me know if it helps!! (also, use the anti-sq. on them to adhere)
-eS
Old May 7, 2004 | 04:16 PM
D_Nyholm's Avatar
D_Nyholm
oops, i threw them out with the pads....I doubt the dealership would have them!
Old May 10, 2004 | 02:07 PM
Gilgamesh's Avatar
Gilgamesh
I had to take off about .004 per side on the HPS ti make 'em fit...no knocking around as they were still snug...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
samansharif
Sep 25, 2015 12:31 PM
