Tire Pressure Sensors
Old Sep 24, 2004 | 10:47 AM
Anthony 98 GTS's Avatar
Anthony 98 GTS
Default Tire Pressure Sensors
I just installed a new set of 19" Volks. How do I get the tire warning light to turn off??
Old Oct 3, 2004 | 06:41 AM
dave843's Avatar
dave843
Default Re: Tire Pressure Sensors
The best way to get it to turn off is to get tire pressure sensors and install them on each wheel. Then register the TPS sensors with the BCM/ECU, and the tire pressure monitoring system will work again. Unfortunately, that is a very expensive option. The sensors are more than $200 apiece. And you need 4, so that's more than $800. Ouch.
When exactly does your light come on? With my aftermarket winter rims, the light comes on after driving for 30-45 minutes. It turns off when I turn the car off and start it back up again. I just ignore the light when I'm driving on those rims.
Old Oct 4, 2004 | 05:26 AM
Anthony 98 GTS
Default Re: Re: Tire Pressure Sensors
Thanks for the response. My light is on all the time.
I still have my stock wheels - will those sensors work with my Volks??
Old Oct 4, 2004 | 03:09 PM
ganninia's Avatar
ganninia
What?? The tire sensors are not really that functional, at least for me and many others. I just leave it on or ignore it. My sensors come on and off as they please, even though I haven't had it for teh last 9 months. Or you have it turned off. I forgot, but someone mentioned how they had it turned on in the ECU. I think it was on [url]G35driver.com[\url]
Old Oct 14, 2004 | 09:49 PM
stiv's Avatar
stiv
I got the long pressure warning chime 3 or 4 days after putting some air in my tires. The tire pressure is fine according to my digital tire gauge but the low pressure icon still lights up when I fire up the VQ. I'm guessing that the sensors still have some issues that need correcting.
Old Mar 18, 2005 | 11:52 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
is there a way to disable the TPS system if I remove the sensors (when I put aftermarket wheels on) ?
Old Mar 18, 2005 | 06:51 PM
GZire's Avatar
GZire
As far as I know, you cannot turn the system off.
The TPMs might fit into certain wheels, but you don't know until you try. You have several options.
1. TPMs fit.
2. TPMs don't fit, strap them onto the center of the wheels inside the tires (you can have some balancing issues and you need to make sure the bands that you strap the TPMs on with don't move/bust loose).
3. TPMs don't fit, throw them into your spare tire. Don't really know if this will work, but I have heard of at least one guy who did this. Downside it spare tire is (probably) not usable in this condition.
4. TPMs don't fit, leave them off and deal with the TPS alarm.
Old Mar 18, 2005 | 06:55 PM
35ounces's Avatar
35ounces
03 CS Track 6MT
1. TPMs fit.
-they don't fit
-i don't want to strap them on (people have had problems with them and my tires are mounted already).
-spare tire doesn't work (or so I've been told - need to confirm)
-really want the light OUT (bottomline here).
Are you saying that there is no way to disable the TPS management system ?
If I must I will kill the LED but Id rather solve it some other way.
Old Mar 21, 2005 | 04:48 PM
GZire's Avatar
GZire
OK.......try this. Check out this link.
http://www.g35frenzy.com/forum/showthread.php?t=1044
There's information from the service manual (not owner's manual). The answer to (disabling) the TPM light might be in there. Sorry man this is the best I can do, wish I could give to a definite answer.
Old Mar 21, 2005 | 08:33 PM
Import-Tooner's Avatar
Import-Tooner
I may just take my gauge cluster apart and put a piece of black tape under the bezel between it and the light. I don't want to take the light completely out but I have heard that tps sensors won't work with SF-Challenges. Mostly becuase they are not a one piece wheel or something.
Old Mar 22, 2005 | 04:47 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Yeah I'm thinking of doing the same. Seems to be about all you can do.
Unplugging the TPMS receiver doesnt seem to do the trick.
I dont really get it though. Some of the Z models dont come with TPS at all. It must just be a matter of pluggin in the electronics.
Old Mar 22, 2005 | 06:18 AM
Wedge's Avatar
Wedge
If your TPS light stays on after installing aftermarket wheels without sensors, it is an oddity. Most people (including me) don't get the warning light staying on all at all times in this situation since there is no signal being transmitted.
What does happen however, is that after about 45 minutes or so of steady driving, the light will come on due to being programmed to report a "no signal" (from the sensors) condition. If you still had the sensors, this warning would indicate that you may need to replace the battery in the sensor or the sensor is completely shot.
The good thing is, the fix for this is to simply turn the engine off and the light goes out until you have another long drive.
If you have no sensors and the light stays on at all times, I would try the old "disconnect the car battery" fix to try to reset the condition. (several hours should do it). Reconnect and see if the light has gone out.
Old Mar 22, 2005 | 06:22 AM
35ounces's Avatar
35ounces
03 CS Track 6MT
Not saying it stays on. Just the fact that it comes on after 45 minutes is annoying so that's what we were looking to fix.
Old Mar 22, 2005 | 06:43 AM
pdjafari's Avatar
pdjafari
knock on wood but i just installed my wheels thursday nite and have yet to see ANY TPS light come on....i have an 04.5 G35C....
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
