AAM SPEC Angled Plenum Spacer !Group Buy!
Old Mar 3, 2005 | 11:58 PM
  #261
sakred's Avatar
sakred
yeah i got mine hopefully il install it tomrow followed by a dyno soon after. thank you AA for prompt delivary and i got a tracking number before hand
hammad
Old Mar 4, 2005 | 08:36 AM
  #262
dynamic6er's Avatar
dynamic6er
Originally posted by derek173
how many more did you get??
13 Gaskets had to send out to the owners that gave me their Vin#
Old Mar 4, 2005 | 08:37 AM
  #263
dynamic6er's Avatar
dynamic6er
Originally posted by jester7500
When can I pick mine up?
Called
Old Mar 4, 2005 | 08:38 AM
  #264
dynamic6er's Avatar
dynamic6er
Originally posted by jeffw
I got mine, but I was not emailed a tracking #.
Jeff
Sorry about that Jeff. Sometimes UPS is faster then expected.
Old Mar 4, 2005 | 02:42 PM
  #265
TX-Ruben's Avatar
TX-Ruben
Installation tonight..... woohoo!
Old Mar 4, 2005 | 03:18 PM
  #266
joust75's Avatar
joust75
Before submitting a group buy these guys should ship out valium suppositories to the buyers to prevent this "when do I get mine whendo I get mine" craze
Everyone needs to calm down and realize that the stuff will get there when it gets there.
The bitching and moaning will only slow down the process!
Old Mar 4, 2005 | 03:23 PM
  #267
Zquicksilver's Avatar
Zquicksilver
MMMMWHHHHAAAAAAAA.....MMMWHAAAHAAAAAA!!
Old Mar 4, 2005 | 05:28 PM
  #268
islandsnow's Avatar
islandsnow
that's the most peanuts packed in the box i ever saw, great packaging. I'll be installing tonight too, let you know how the butt dyno feels if it stops raining here.
Old Mar 4, 2005 | 06:27 PM
  #269
M23's Avatar
M23
Hello Dave,
I emailed you my #vin long ago, am I getting mine soon? (I ordered 2 actually)
Thanks
Old Mar 4, 2005 | 11:40 PM
  #270
Sins4u33's Avatar
Sins4u33
yours is shipped out, hope you get it soon.
Ben Y
AAM
Old Mar 5, 2005 | 03:28 AM
  #271
cox's Avatar
cox
News for Italy? (I've ordered 2 Kits)
Thanks
Old Mar 5, 2005 | 06:58 AM
  #272
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Dave, what's the deal on the wrong bolts thing? A few guys are saying the bolts that came with the spacer weren't correct. Has this been corrected and if so when?
Old Mar 5, 2005 | 11:09 AM
  #273
roark's Avatar
roark
Default Plenum Spacer Installed...
I installed my AAM plenum spacer today. Here are my thoughts.
Installation: First, the spacer is a thing of beauty. I love stuff that's done on a CNC machine. The instructions work as written (but the bolt size and qty. in the parts list is incorrect.)
I did, however, have to go out and buy quite a few more bolts because the stock bolts were not long enough. The kit came with six M6x30mm, but I found that I had to replace the back three center bolts (M6x60mm) with three M6x70mm. I could have used those 60mm bolts in the front three center holes, but wanted the heads to match, so I purchased an additional three M6x60mm too. I also had to purchase five M6x35mm bolts for the front-most connection points, since even the ones included in the kit were not long enough.
performance:It's too rainy here today to get on this thing and see what the butt dyno says. I did what I promised earlier, however. I went to my local DynoJet this morning before the install and got two pulls. I did two more pulls after the install. I also tested this mod with my G-Tech before and after. Here are the results of the two types of tests. Each display includes a pair of baseline runs from when the car was stock, then a pair this morning before the install, and finally a pair after installing the plenum spacer.
On the Dyno
What the G-Tech says
before you go asking all typical G-tech questions, yes it always shows lower net HP because of the aero drag of a moving vehicle.
So basically, the SAE corrected DyoJet says I gain approx. 5WHP and flatten my torque curve a bit. The G-Tech claims more like 9WHP, which after correcting for drag is more like 11-12WHP. I won't argue the difference in the tests in this thread, but I'll assume that the truth lies somewhere in the middle.
Am I happy with this mod. Yes, given the HP/$ ratio, it's not bad. I believe (and my data backs me up) that I really need an ECU reflash next to take advantage of the intake & exhausts mods I've got.
Would I recommend this mod? I'll have to say "It Depends" and leave it at that.
Old Mar 5, 2005 | 11:44 AM
  #274
mpowers's Avatar
mpowers
Nice results Roak!
Old Mar 5, 2005 | 12:08 PM
  #275
Nano's Avatar
Nano
what are your other mods roark?
definitately will blow the 250whp mark with a reflash.
maybe the spacer needs to settle a little. Should have waited a couple of days for ECU to adapt before dynoeing. Good results nonetheless.
Old Mar 5, 2005 | 12:11 PM
  #276
jester7500's Avatar
jester7500
I got my kit yesterday, and as the same problem as roark, the proper bolts were not provided. For anyone who hasn't installed it yet, I highly recommend getting the bolts that roark stated above before you install. I found this out the hard way. I never removed my upper plenum before so I didn't know about the different sized bolts. Plus the instructions didn't state to use M6x70mm for the upper 3 center bolts. But no biggie, I'll just run to Home Depot and pick up the right bolts.
Old Mar 5, 2005 | 06:36 PM
  #277
xxlbeerZ's Avatar
xxlbeerZ
I plan on purchasing one of these in the future, hopefully they have the bolt situation corrected by then.
Thanks for the dyno chart, looks like a good mod!
Looking at it in person do you actually feel it distributes the air better across the cylinders? I'm more interested in this for my FI application, preventing the 5&6 cylinder lean condition...
Old Mar 5, 2005 | 06:37 PM
  #278
vlm7's Avatar
vlm7
Default AAM Spacer
Notwithstanding AAM's indication that there would be no fitment issues for 03 models, I had the same bolt issue as the above posters. I went to Home Depot and Lowes and an auto parts shop and could not find the M6x70 bolts. AAM - please send these bolts out to all of those that have already received (and picked-up) the spacer with the inapporiate bolts.
Old Mar 5, 2005 | 07:56 PM
  #279
nuni's Avatar
nuni
my kit includes the plenum spacer the gasket m10*1*30mm bolts*{4} washers with intergrated o rings *6and 24 spacers the only reason iam posting this cause i seem the guy who posted before me had a diff list
Old Mar 5, 2005 | 09:11 PM
  #280
joust75's Avatar
joust75
Punctuation is your friend nuni. Use it and prosper.....
