AAM SPEC Angled Plenum Spacer !Group Buy!
Old Mar 14, 2005 | 02:50 PM
  #321
dynamic6er's Avatar
dynamic6er
Originally Posted by Road Warrior
please explain what you mean by E6...socket....and where can you get it?
E6 is the size of the TORX/Star head on the two studs, numbers 12 and 18 on the diagram. A set of these can be picked up at Sears, Home Depot, etc.
Old Mar 14, 2005 | 02:52 PM
  #322
cmouton's Avatar
cmouton
It's a torx socket. Tough to find outside of an auto parts store. I ended up having to buy a complete set of 8 or 10 from Advance Auto just to use the smallest one for those bolts. Fortunately, they only cost $11.
Old Mar 14, 2005 | 02:54 PM
  #323
Nano's Avatar
Nano
the magic of the interweb
Results 1 - 20 of about 49 for E6 socket. (0.03 seconds)
http://images.google.ca/images?q=E6%...r=&sa=N&tab=wi
than comes the magic of home depot, I'll let you figure that one out.
Old Mar 14, 2005 | 02:56 PM
  #324
derek173's Avatar
derek173
Originally Posted by derek173
Do we have an estimate on when all the orders from the group buy should be finalized?
I also saw that http://www.performancenissanparts.com sells the gaskets in large quantities, give them a try maybe?
Old Mar 14, 2005 | 04:00 PM
  #325
alininger2001's Avatar
alininger2001
Those studs are too short to use anyways, I used a vice grip( Warning be careful, grab the stud as far down as possible) to get the studs out and hen I put a bolt in their place, I believe the bolt was a 40 mm bolt. Having alot of 40 mm bolts laying around really helps by the way. Pesonally I felt that some of the stock bolts or the shorter bolts (25mm) that were included in the kit were two short. I believe you need three 60 mm bolts, four 70mm bolts, and the rest can be replaced with 30 and 40 mm bolts. I did not feel that any of the stock bolts were very useful, when I put them in they didn't go all the way through the threaded holes.
Old Mar 14, 2005 | 05:53 PM
  #326
xziteme's Avatar
xziteme
I'll be installing this tomorrow and I want to know if these are the right size bolts to replace the stock bolt?!
3,1,6 = M6X75MM
5,2,4 = M6X60MM
7,11,12,13,14,8,9,15,16,17,18,10 = M6X35MM
Old Mar 14, 2005 | 07:31 PM
  #327
islandsnow's Avatar
islandsnow
AAM thanks, got my bolts today! Thumbs up on the quality product, it's making driving to work a lot more fun!
Old Mar 14, 2005 | 08:28 PM
  #328
BlackZ33's Avatar
BlackZ33
Default More reviews?
Does anyone have more reviews of their install and driving impression?
Thanks
I am in the middle of the install and got stuck!
Old Mar 14, 2005 | 08:57 PM
  #329
BlackZ33's Avatar
BlackZ33
3,1,6 = M6X75MM
5,2,4 = M6X60MM
Same question here!
The stock bolts are too short !
And the bolts I received are not enough to replace all the shorter stock bolts
Old Mar 15, 2005 | 08:37 AM
  #330
Zquicksilver's Avatar
Zquicksilver
3,1,6 = M6X75MM
5,2,4 = M6X60MM
I have not installed the spacer yet…
What AAM is suggesting in their revised instructions is;
10. Place bolts into center of plenum.
a. Begin to thread bolts by hand.
b. Bolts 1,3,6 are M6x60mm
c. Bolts 2,4,5 are M6x45mm
d. Revision: Replace bolts 1,3,6 with the supplied M6x1x75mm. Position the Standard washer against the head of the bolt then the O-ring washer.
e. Revision: Move the M6x60mm bolts to the front holes 2,4,5.
11. Insert bolts 11 through 18 into the appropriate holes.
a. Begin threading them in by hand.
b. Bolts 7,8,10,11,13,14,15,16,18 are M6x25mm
This is what I may do just to be safe…see illustration
I've received (3) 75mm bolts and (6) 30mm bolts from AAM. I will probably use those along with (6) new 35mm bolts for the front.
Old Mar 15, 2005 | 09:15 AM
  #331
Road Warrior's Avatar
Road Warrior
i guesss i'm just a bonehead....those are the same one's i just used on the header studs....
thanks bro.....03 seconds....smart ***
Old Mar 15, 2005 | 09:19 AM
  #332
the7ferret's Avatar
the7ferret
I havent gotten my spacer yet but are thier torque values?
Or should we go with OEM values?
Old Mar 15, 2005 | 12:17 PM
  #333
derek173's Avatar
derek173
anyone suggest using Thread locker on the bolts?
Old Mar 15, 2005 | 01:17 PM
  #334
Road Warrior
are they not on the instruction manual?
Old Mar 15, 2005 | 01:50 PM
  #335
the7ferret's Avatar
the7ferret
I dunno, i havent gotten the kit yet.
Old Mar 15, 2005 | 03:15 PM
  #336
derek173's Avatar
derek173
Old Mar 15, 2005 | 03:54 PM
  #337
nuni's Avatar
nuni
got mine installed yesterday let me tell u something this is a kick *** product my car feels a lot faster 2 thumbs up
Old Mar 15, 2005 | 05:46 PM
  #338
flash's Avatar
flash
I got a late start. Any chance of another group buy?
Old Mar 15, 2005 | 06:42 PM
  #339
islandsnow's Avatar
islandsnow
When i installed it, I felt a lot more torque and faster revving up to redline, just seemed to make the engine breath a lot easier and made it a lot funner to drive. Seemed easier to get those 2nd gear chirps again. I do have a lot of exhaust bolt ons so maybe this is balancing my car out better. I didn't reset the ECU, just let it self adjust.
For the install, it was pretty easy, the bad thing about 2002/early 2003 Z builds is that they used ***** bolts for the strut bar. It's easy to strip the bolt heads on these early model Z's so i had to drill some of the heads off to get the strut bar off. When you install the plenum spacer, once the center bolts are in, the side screws are easy to get on. The oem specs are only like 7in lbs or something like that, not even ft/lbs, so be really careful if you use the stock shorter bolts. You should be able to get the plenum back on tight enough with the supplied screws. I've been running without long bolts till today, just put them in, still running great. I don't think you need loctite, but i would check the screws again after a couple of weeks just to make sure they are still tight. If you are worried about anything flying off, you shouldn't, theres like 18 bolts holding this thing on.
Old Mar 15, 2005 | 08:03 PM
  #340
BlackZ33's Avatar
BlackZ33
Thanks for the detail review Islandsnow!
I am not really good at mechanical things
The instruction says " place washer with intergrated o-ring below bolts"
But I just don't understand what it really means!
Where should I put the O-ring washer?
Is it inside the plenum? or on the surface of the plenum?
What sizes longer bolts did you use?
I am still stuck in the middle of my install, cannot drive my car for 2 days already
