AAM SPEC Angled Plenum Spacer !Group Buy!
Old Mar 7, 2005 | 08:02 PM
  #301
Tex Willer's Avatar
Tex Willer
lol this thread is funny.
People complain it takes too long
then people complain it was rushed
ROFL
if the bag was ripped, you should have filed a claim with the carrier, no? It's your right and responsability to inspect packages when they are delivered. I don't understand where AAM is at fault here.
Old Mar 7, 2005 | 08:08 PM
  #302
mikedZ33's Avatar
mikedZ33
I just recieved my spacer today. I would prefer the 6 matching bolts at the proper length please.
I was also wondering if those of you who have already installed had any problems with the strut brace. How many spacers did you guys end up using?
Old Mar 7, 2005 | 11:28 PM
  #303
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Does anyone who purchased/installed have the JIC Strut Bar? I am concerned about fitment since there is no room under the hood for the bar to go any higher
Old Mar 8, 2005 | 01:50 AM
  #304
the7ferret's Avatar
the7ferret
6 bolts matching length, havent recived it yet so i dont think its been sent out.. Thanks
Old Mar 8, 2005 | 07:25 AM
  #305
roark's Avatar
roark
The total list of bolts I purchased to make the kit work:
M6x70mm - qty 3
M6x60mm - qty 3 (optional)
M6x40mm - qty 3
M6x35mm - qty 4 (40mm will work here too)
M6 flat washers - qty 13 (optional)
strut-bar to hood clearance 4.5mm minimum (near the ends) and 10.5mm at the center. strut-bar to upper plenum clearance 4mm minimum.
Old Mar 8, 2005 | 09:42 AM
  #306
t350z's Avatar
t350z
Is AAM automatically sending out the correct bolts or do we have to request them? Received my spacer yesterday with only 4 bolts, I would like 6 matching bolts please.
T.
Old Mar 11, 2005 | 04:55 PM
  #307
alininger2001's Avatar
alininger2001
I installed my spacer the other day! I had to get 4x70 mm bolts, 3x60 mm bolts, and I used 6x40 mm bolts I had laying around. I used some of the 25 mm bolts that they sent (there were 4 of them) I only used maybe two stock bolts. The piece fit great, but the bolts and instructions could use improvement. FYI I only used two washers under the strut bar, three would cause the hood to buckle.
Old Mar 11, 2005 | 05:03 PM
  #308
vlm7's Avatar
vlm7
I got my bolts in the mail today from AAM. They sent three M6x75 bolts and washers. The complete finished product is great!
Old Mar 12, 2005 | 07:42 AM
  #309
jester7500's Avatar
jester7500
I got my bolts this week too. Thanks AAM for the prompt service!
Old Mar 12, 2005 | 10:43 AM
  #310
dynamic6er's Avatar
dynamic6er
T.
We sent everyone that recieved the wrong bolts as complete set. Should see in a few days if not already. Thanks!
Old Mar 12, 2005 | 05:42 PM
  #311
speedform's Avatar
speedform
Still waiting on my spacer. I thought I was one of the first guys who paid too. I'm not sure what's going on but after repeated phone calls and pm's to AAM, I'm starting to get a little frustrated.
The bright side is that if it hasn't been sent yet I might get the proper size bolts with it!
Old Mar 13, 2005 | 06:21 PM
  #312
derek173's Avatar
derek173
Do we have an estimate on when all the orders from the group buy should be finalized?
I also saw that http://www.performancenissanparts.com sells the gaskets in large quantities, give them a try maybe?
Old Mar 14, 2005 | 09:25 AM
  #313
Zquicksilver's Avatar
Zquicksilver
M6x70mm - qty 3
M6x40mm - qty 3
Will someone "fill in the blank" with correct bolt sizes on the illustration I have posted? Or send me the bolt sizes in text form matching the numbers in my illustration and I will Photoshop a new image for everyone.
I have not installed by spacer yet, but want to be prepared when I do. I hope this will help others. I am not trying to post conflicting information with the AAM kit, I'm sure with the matching bolts it works fine. I'm just choosing to go with the longer bolts, similar to Roark.
Zquicksilver
Old Mar 14, 2005 | 09:29 AM
  #314
Road Warrior's Avatar
Road Warrior
they have corrected the problem and are now sending the right size bolts with their packages along with a corrected installation revision on where the different size bolts are supposed to go
Old Mar 14, 2005 | 10:00 AM
  #315
Zquicksilver
Good to hear...but I received my spacer kit last week with the 6 matching bolts @ 30mm, is this AAM's final release and solution to the bolt issue? Is this suppose to work with swapping existing bolts around? I'm not sure this is the perfect solution according to others who have already installed and seem to have bought a variety of bolts. I am happy with AAM and the group buy, and buying some extra bolts is no problem if it's the BEST solution.
I'm installing my spacer in April, so at this point I'm edgaumacating myself
Old Mar 14, 2005 | 11:37 AM
  #316
Road Warrior
i haven't installed mine yet...but i have bought extra bolts just in case....so i am really not sure if the new version is perfected....but there is a revision and it should be stated in your directions if its the new kit.
i will be installing next weekend....so i will let you know then what's up
be nice if aam would jump in here and clear things up, eh
Old Mar 14, 2005 | 12:10 PM
  #317
dgz32's Avatar
dgz32
Yeah...the directions are a bit vague. The install, though, is quite straight foreword...if that makes any sence.
Not mentioned in the directions is the removal of the studs in the lower plenum - there is one on either side. You'll need a star socket (E6) to remove 'em.
Old Mar 14, 2005 | 02:17 PM
  #318
nuni's Avatar
nuni
i installed the spacer today but left out two screws how bad is that?
Old Mar 14, 2005 | 02:19 PM
  #319
dynamic6er's Avatar
dynamic6er
We actually decided not to utilize those posts for a bolt becasue we assumed that most people would not have the right tool. We use them essentially as locating pins. We foudn that the plenum would hold all the pressure we threw at it andsealed properly without them.
Old Mar 14, 2005 | 02:25 PM
  #320
Road Warrior
please explain what you mean by E6...socket....and where can you get it?
