AAM SPEC Angled Plenum Spacer !Group Buy!
Originally Posted by t350z
Now there's a good idea.
just having the right sized bolts is an easy and very affordable solution to the problem....and applying the correct torque
Originally Posted by Road Warrior
my question was will these 2 ea. E-6 bolts need to be longer too, or just removed completely....sorry for the confusion
I am also confused by this. What exactly needs to be done with the E-6 studs?
removing them is optional = you can leave them there
Dave, I placed my order bout 3 weeks ago and my check was cashed two weeks ago. May I please have an e-receipt or an order confirmation sent. I would like an ETA as well if you can figure this out.
I will continue to be patient , thanks.
Julien
Julien
i am having a hard time finding local hardware stores that carry these size bolts posted previously (although not required i am going to replace the bolts to our corrected sizes)...anyone have a website recommendation?
well i installed the spacer a little while ago even though i was unable to obtain the desired hardware. imo some of the bolts are too short that are reused so it will be up to the person installing as to whether or not he/she is comfortable with the sizes.
one thing that i found to make the install much easier is to remove the intake tube that connects to the throttle body and air box. this will allow you to move the plenum more easily and to make sure everything is lined up properly. you can do it without removing this tube but the plenum is much harder to move around and keep into place and the tube creates a binding feeling because it doesn't allow much movement. also, the 6 center bolts needed to be retorqued 3-4 times once everything is seated...the other bolts seemed to remain torqued after the first time i torqued them down.
i didn't get but one run in after the install and performance wise i can tell you there is a difference. i installed headers last week and the gains were barely noticeable. the plenum spacer you can really feel the difference.....hard pull throughout the powerband.
since i didn't do a dyno i don't really know how much power i have gained...but i am very happy with the butt dyno results. good luck to the rest of you'all...later
rw.....oooouuuttt
rw.....oooouuuttt
yes they are hard to find I went to ten places with no luck. I ordered them from here
http://www.boltdepot.com/
here is my order
Metric hex bolts, Metric partial thread bolts, Steel grade 10.9, in following sizes :
6mm x 1.0, 35mm
6mm x 1.0, 30mm
6mm x 1.0, 40mm
6mm x 1.0, 60mm
6mm x 1.0, 70mm
I installed mine today, went to napa they had a drawer with the 35mm bolts and the number 6 washers for front of Plenum... dude just gave em to me free :-) the spacer took about 20-30 min to install... besides testing the strut bar heights... I used 2 spacer washers on both sides of the strut bar.
I am no gear head at all I only opened the hood once to install a pop charger...this install was super easy...figuring out the bolt and sizes took no more then a couple min..its common sence.
I am getting a low end vibration from somwhere though...
and what about the 2 studs that are too short with no nuts tieing them down???
the kit never came with those or replaced them, and I think it should.
its almost half *** to not have those.
over all drove the car 200 miles today after install, and the powerband is accepable at my alt 5000 feet, feels nice and strong, not to mention the added NOISE :-)
My install:
unbolt strut bar
unbolted all the bolts for Plenum
un bolt air intake (at the throttle body) and un-clip the wire harness
Lift Plenum straight up and slid in spacer/w/gastket, set down and bolt back up.
My install:
unbolt strut bar
My install:
unbolt strut bar
My install:
unbolt strut bar
i used the same amount of washers on my strut bar too and replaced those studs with bolts
The JIC strut bar does NOT fit with this spacer =/...I really like the look of this bar but I dont want to risk dremmeling the underside of my hood and squeezing it under there b.c. I am sure when the engine rocks I will start to dent my hood. As far as the install I couldn't find the bolts that those who already installed suggested and I was too impatient to waiso we just used the ones that came with it...The spacer is installed but The front most bolt was too short so i left it out for now and will need a 35mm to fill that void. I got some suction from air leaking through some of the bolts/washers so we had to tighten them up more(scarry) and use some little rubber gaskets. I think it's running ok now and I can feel the gains so all is well...Just bummed over that strut bar right now.
sorry to hear your JIC won't work...hopefully you can find a way to make it fit!!
just curious...where were your air leaks? how did you know that they were leaking and did you use the specified torque? did you use the rubber washers that came with the kit?
Yes we used the washers and torqued to spec, I am not sure where my problems came from but if you have a leak you will know it. I had a very noticeable hiss that I could hear from in and out of the car. Also if you place your hand over the area you suspect may be leaking there will be suction. I hope the bat will be able to fit also but I dont think it's possible.
i didn't really check for leaks but thats a good idea to make sure everything is sealed.
on the JIC...is there any adjustment....i had to adjust my stock strut bar to get the holes to line up after putting in the spacers.
Too bad it was raining yesterday when i put mine on. I couldn't notice any real gains.
But ill try later today when i go to the mall.
I want to make sure that I understand this correctly. So you do not have to remove throttle body from the upper plenum. Just the remove the plastic air tube that connects to the throttle body and it will lift up freely.
