installer put on my stock header gasket!
Old Feb 17, 2005 | 07:17 AM
o snap its eric's Avatar
o snap its eric
Default installer put on my stock header gasket!
I bought them some brand new ones but they used the ones there were on my oem headers. IS there anything bad about re-using old header gaskets? Am i prone to a leak now?
Old Feb 17, 2005 | 07:38 AM
spazpilot's Avatar
spazpilot
Nope they are metal, I would just get your money back on the new ones and not worry about it.
Old Feb 17, 2005 | 07:47 AM
Zivman's Avatar
Zivman
Default Re: installer put on my stock header gasket!
That's why I install my own parts
You should be fine, the OEM gasket is good, most likely better than the the aftermarket one you provided. They can be reused because they are metal.
What headers did you go with?
Old Feb 17, 2005 | 07:49 AM
o snap its eric
i went with DC and i had my cats installed at the same time. I had cats before before they cracked on me but i must say there is a definite gain all around the powerband along with some weight savings and more responsiveness. THe cat and header combo is definitly worth the install. My car now roars! No joke. Are WOT its very intiminating.
Old Feb 17, 2005 | 07:57 AM
Zivman's Avatar
Zivman
What cats and exhaust are you running? I have Topspeed headers with labree resonated test pipes into a Greddy EVO2 and the car just "sings"
Old Feb 17, 2005 | 08:09 AM
Tony@Performance's Avatar
Tony@Performance
Vendor - Former Vendor
unless the gaskets are bad, don't worry about changing it out. you can re-use those with no issues
Old Feb 17, 2005 | 09:54 AM
o snap its eric
thanks guys! I was worried for a bit. Installing headers is costly.
I am running nismo exhuast, JWT intake, Z-tube, Kentix Cats, and now DC headers.
I would make a sounds clip or drive by and idle revs but i dont know how to. So if someone from the bay would like to help i would gladly do it. But man, its mean sounding.
Old Feb 17, 2005 | 05:24 PM
alininger2001's Avatar
alininger2001
Don't worry, the gasket is probably in the same exact condition as the new ones, mine were.
Old Feb 17, 2005 | 07:45 PM
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
he did you a favor if your headers came with paper gaskets...
the factory gaskets are metal and superior to all the after market gaskets i have seen for the head - manifold and manifold - cat gaskets...
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
z33z_nutz
Sep 23, 2015 07:22 PM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
EnjukuRacing
Sep 9, 2015 06:42 AM
