resonated test pipe vs Non-resonated
Old Feb 23, 2005 | 02:36 PM
100122923's Avatar
100122923
Default resonated test pipe vs Non-resonated
which one flows better and gives u the most power?
can someone plz answer this question
thx
Old Feb 23, 2005 | 02:55 PM
myz8a4re's Avatar
myz8a4re
the resonators will hinder the flow slightly, not enough to worry about though. the reason for the resonator is to eliminate the exhaust rasp that most have & complain about on the z. i have the kinetix resonated testpipes & my exhaust sounds clean as can be. the kinetix resonated & non resonated version made the same hp on the dyno, but resonators are known for slightly slowing flow just as a muffler does...........
-justin
Old Feb 23, 2005 | 03:57 PM
100122923's Avatar
100122923
Thx Justin, really appreciate your input ^^
Old Feb 23, 2005 | 05:51 PM
DIE DIE's Avatar
DIE DIE
100122923- don't get testpipes without resonators!!!!!!!!! They sound like ****.. Just do a search if you don't believe me... Theres like 10540898 helix TP for sale threads, cause everyone gets rid of them right away!!!!!!! <--wait actually.....you wanna buy some helix TP off me for $100
Old Feb 23, 2005 | 06:02 PM
leemik's Avatar
leemik
I've always wondered the same too but I got resonated test pipes recently and it's pretty much straight through unhindered like a regular test pipe.. if my arm was small enough I could put it right through the pipe with no obstruction..
There is a bulge in the resonated pipe and some honeycomb material lining the sides there.. that must do "resonating" I guess.. Don't know how it works but air flow probably gets a little turbulent at that section causing a very slight hinderance vs a straight pipe..
but yeah definately get resonated.. non is very raspy and nasty sounding between 2000-3000rpm ..
--mike
Old Feb 23, 2005 | 06:08 PM
hndumafia's Avatar
hndumafia
unless you're f/i you should really get resonated test pipes, unless you can deal with the rasp. it sucks that they cost more, but if you get regular test pipes you're gonna end up wanting to change to resonated test pipes.
my kinetix resonated test pipes added power (or so the butt dyno said) and they do not rasp.
Old Mar 18, 2005 | 09:29 AM
E_Z_HOES's Avatar
E_Z_HOES
If you Turbo charge our cars and have non resonated test pipes does it still make the raspy noise?
Old Mar 25, 2005 | 07:45 PM
TunaRollZ's Avatar
TunaRollZ
possibly...but your chances are much better to not have rasp w/ a twin turbo set up. Turbos act as excellent mufflers...
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
