Greaddy EvoII install EVAP relocation. HELP!!
Old May 17, 2007 | 11:24 AM
cpttomasz's Avatar
cpttomasz
i know this threads been dead for awhile but does anyone know what the diamter is of the hose zivman was talkin about. i'm gonna try to put this kit on this week reusing the two hoses and havin purchased the 3rd ahead of time. thanks for any help..
Old Mar 26, 2008 | 07:17 AM
Spoiled Z's Avatar
Spoiled Z
Zivman - when you say The hose that is lined green is the one you would need to extend. Which one is that. The small or big hose? The kit came with 2 hoses one is small and one is twice as big as the other one. I'm installing the exhaust tomorrow.
Old Nov 25, 2008 | 10:18 PM
urbanchaos's Avatar
urbanchaos
Originally Posted by speedform
Ok....I've got the EVAP unit out (Thanks Jeff) and now it's all bolted up to the chassis.
New problem........Greddy supplies 2 extension hoses for the Evap relocation but it looks like I'll need 3? Did Greddy not give me enough hose extensions or am I missing something?
Ok I got all my stock exhaust off and now I'm messing with the evap trying to get it off. I cant get it off and I don't see and other nuts holding it in place. What was you solution on removing it cuz it seems we have the same problem. Or if anyone else can answer this please do. The only thing I can think of is theres one in back and I would have to remove the bumper?
Old Nov 26, 2008 | 02:37 AM
urbanchaos's Avatar
urbanchaos
^^ Nevermind I got the dual tic and it fit. The exhaust is about 3 inchs from the hose and I just put the heat rap around it so it should be good.
Old Oct 30, 2009 | 01:57 AM
djtrickz's Avatar
djtrickz
Thanks Zivman. Great illustration!
As far as the longer hose that extends into the chassis, I just pulled it out of the chassis and jammed it through another hole I found. It looks like it's just a vent hose.
Your hoses must have been longer on your car because there was no way the other two would extend far enough to reach the box without the extensions. :/
I know this is old, but I need an answer! Since the long hose just extends to the chassis and doesn't really connect to anything, can you just take it off all together? If not, can someone explain to me why? Thanks!
Old Nov 22, 2009 | 09:53 PM
Waiz's Avatar
Waiz
Contact Greddy directly, they sell the kit for about $75.
Old Nov 23, 2009 | 06:36 AM
rcdash's Avatar
rcdash
Greddy sells a kit to move the EVAP canister back to stock? If anyone has the part # for the stock bracket from Performance Nissan, please post up. I'm not sure a custom bracket exists or is needed, just checking with folks that have moved the evap canister back to stock...
sales@czp
Sep 23, 2019 03:30 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
