Kinetix V5 plenum cracked.....
Old Mar 24, 2005 | 03:41 PM
  #41
taurran's Avatar
taurran
I don't see why it would have any issues with mild boost. Do you really think 10psi would make the plastic burst? I think the only concern should be with the actual plenum gasket. In this case, the kinetix uses the stock plenum gasket and also adds a cork buffer. Is this 'buffer' your cause for concern?
Anyway, if it's not adequate I would rather polish my stock plenum and go with a spacer. Anything is better looks-wise than the Crawford. It looks like someone took one of granny's frying pans and bolted it to the engine.
Old Mar 24, 2005 | 03:54 PM
  #42
SungNamZ's Avatar
SungNamZ
"Turbonetics Single Tubo Kit" coming soon. I have had ZERO problems with my V4 with Vortech SC. Why don't you give Kinetix a few days to see what they might announce on their intake manifold. It is suppose to be for FI.
Old Mar 24, 2005 | 03:58 PM
  #43
taurran's Avatar
taurran
Yeah. I'm saying that I don't think I will have issues with my v4 plenum as long as I'm running stock boost. I know that you Vortech folks have had no issues running them with the stock 8psi. I'll just make sure to take the plenum bolts out and locktite the s**t out of them.
Old Mar 25, 2005 | 12:55 AM
  #44
captj3's Avatar
captj3
Originally Posted by xephiron
Just curious, why selling your Kinetix V4?
APS TT I don't want to take a chance with it.The TT's develope full boost at a lower RPM's.Other than that I think it's a great mod.If any one is intrested it's stll available.
Old Mar 26, 2005 | 04:25 AM
  #45
zachcrosen's Avatar
zachcrosen
Any updates yet Robert on your aluminum plenum? I am eagerly awaiting a 1 piece plenum designed for F/I applications!!!
Old Mar 27, 2005 | 04:13 PM
  #46
aaronrus's Avatar
aaronrus
does the plenum void the factory powertrain warranty? i know there is much debate in other forums about intake modifications voiding warranties, and i know EVERY dealer will tell you they do, but most dealers also lie. does any body have definitive answer/proof? and what about cold air intakes as well?
Old Mar 27, 2005 | 04:19 PM
  #47
abstrakt's Avatar
abstrakt
i think the dealer has to prove that the mod caused whatever problem you are having. if the mod is the cause of the problem then the warranty becomes void
Old Mar 27, 2005 | 04:58 PM
  #48
zachcrosen's Avatar
zachcrosen
The Moss Mangussen (sp?) Act states that the dealer must prove that the mods done to the car are a direct cause of the failure to void the warranty. I say do the mod and if you have any problems after installation of that mod, replace the OEM plenum or intake or whatever other mod you have done if possible. If you are that worried about voiding your warranty, just dont mod the car.
Zach
Old Mar 27, 2005 | 08:36 PM
  #49
ReavTek's Avatar
ReavTek
So is this complete intake manifold setup strickly for FI? I am very interested in making a potent NA 350Z so I have been keeping a close eye on the whole plenum debate... 350EVO has made it clear their setup is for NA Zs how about Kinetix?
Old Mar 28, 2005 | 04:12 AM
  #50
SungNamZ's Avatar
SungNamZ
The Kinetix Intake Manifold should have a positive impact on both NA and FI. Hopefully numbers from both applications will be posted in the near future.
Old Mar 28, 2005 | 05:58 AM
  #51
zachcrosen's Avatar
zachcrosen
The last I heard about it last year was that it was designed for F/I but they were tweaking with it to get some gains out of a NA Z. I wish Robert would chime in here and post some pix and additional info. My Vortech install is growing near.
Old Apr 13, 2005 | 09:26 AM
  #52
Cbr's Avatar
Cbr
Well Kinetix Racing comes through once again!, I recieved my new replacement plenum today, although it took a little time, all is well
Kinetix Racing = A++++ for Customer Service
Thanks again
Old Apr 13, 2005 | 11:47 AM
  #53
maximumsportZ's Avatar
maximumsportZ
Thanks again
Are you coming out tonight to the meets at UC7?? I would like to see one in person.
Old Apr 15, 2005 | 02:54 PM
  #54
bwzabodyn's Avatar
bwzabodyn
...Greddy TT's are blowing engines but people are still buying them...
the Kinetix V4 is one of the best mods I made to my car... 14hp and 8ft lbs are nothing to sneeze at... and I've had mine since the first GB (ie long *** time ago) and put over 10k miles on it easily... composite intakes wouldn't be used in OE applications if it didn't work... it just took Kinetix four tries to get it PERFECT...
NissanZcrazy
Sep 23, 2015 07:59 AM
little_rod
May 31, 2004 09:07 AM
xlacrosse
May 11, 2004 02:25 PM
syf0n
Apr 8, 2004 01:02 PM
jakeup93
Mar 10, 2004 02:44 PM
