aam plenum spacer review
Old Mar 28, 2005 | 11:28 AM
Road Warrior's Avatar
Road Warrior
Originally Posted by Zquicksilver
Road Warrior,
Wait until you get a conical filter on there! My car pulls hard all the way thru the powerpand and takes off above 4k, after the engine is warmed up. Sometimes it almost feels like my old 86 turbo when it kicked in
I have no idea what the engine is going to do once I install the spacer, from your feedback it's going probably cause me to sink into my seat. I'm actually getting all giddy from the amount of power expected once I get all my mods installed. See sig
Zquicksilver
you will be pleasantly surprised
btw, i took some pics of my modified intake but haven't posted them up yet
Old Mar 28, 2005 | 11:37 AM
NOBI's Avatar
NOBI
the MD spacer, is .5 in, how big of a gap does this one give you??? also, everyone says this thing growls, where does it growl, in the exhaust or up front?
Old Mar 28, 2005 | 11:41 AM
goldndwgz's Avatar
goldndwgz
you can hear the motor breathing better
Old Mar 28, 2005 | 02:09 PM
tommym's Avatar
tommym
yeah, I have had it on my car for a little over a week, and it definately sounds a little louder. I had it installed by Altered Atmosphere, and they did a great job...good bunch of guys. I guess the ECU finally adjusted to it. Now I can definately tell a difference in power.
Old Mar 28, 2005 | 03:30 PM
projectmrod's Avatar
projectmrod
ive been thinking about getting the spacer, has anyone been able to do a test of a stock z+ plenum spacers vrs's sock z+ crawford plenum? just trying to see what has a better gain.. or maybe this question has already been answered..?
Old Mar 29, 2005 | 12:51 PM
Road Warrior
not sure about the comparison in gains....but one must also take into consideration that if you go crawford you must also change out the strut bar too for clearance of the plenum
Old Mar 29, 2005 | 02:26 PM
NOBI's Avatar
NOBI
yea, as far as im concerned this is the way to go. ive never liked any of the plenums released, because they were either A ugly, or B cracked, and C had the hidden cost of having to replace your strut bar. i ask once more, do you know how big of a gap it makes in the front, is it .5 in???
Old Mar 29, 2005 | 03:11 PM
TX-Ruben's Avatar
TX-Ruben
E-mail altered atmosphere.
Old Mar 30, 2005 | 08:09 AM
Zquicksilver's Avatar
Zquicksilver
Yes, it is (.5") inches at front and (.25") at the back.
Old Mar 30, 2005 | 07:24 PM
NOBI's Avatar
NOBI
sweet, thank you zquicksilver, now the real question is: do i want a PSP or a Plenum spacer....
Old Mar 31, 2005 | 09:58 PM
derek173's Avatar
derek173
Ok how is the spacer doing now? Have you guys rechecked your bolts? still holding tight?
Old Apr 2, 2005 | 08:15 PM
Road Warrior
everything is good....i swear every time i take the car out it seems to get a little faster each time....might just be in my head or something, anyways, i am very happy with the results
Old Apr 15, 2005 | 11:19 AM
Zquicksilver
digging it up
road warrior and others...the spacer is awesome! i have around 500mi on it and with no doubt in my mind there as been a change to the engine. it's not psychological! after she's warmed up, the engine revs with so much ease combined with my CAI it's crazy. more growl and more pull throughout the entire powerband!
i'll post some good pics after this weekend...i did have some problems with the strut bar install though, lots of tweaking!
Zquicksilver
ps if you used the longer bolts as specified in my illustration, you can easily use a washer and lock washer or just a lock washer with the a flange/ head bolt and never worry about bolts loosening.
Old Apr 15, 2005 | 01:14 PM
NA&CH's Avatar
NA&CH
How much are these going for normally? very sleeper. me like. Ill check AAM's website. I was also wondering what projectmrod was.
Old Apr 16, 2005 | 05:37 PM
Andys'Z's Avatar
Andys'Z
group buy is over? That sucks, I want one for 175 shipped too... anyway of getting this price again?
Old Apr 19, 2005 | 11:03 AM
Zquicksilver
Well, everything is installed and running great!! The strut bar finally worked after a few combinations with the washers. In my case, I only needed two thick washers for all the strut bolts (except for the pair of FIXED bolts with nuts). For those I used a thin washer half as thick just to be safe for a combination of two thick and one thin. I was amazed at how much the strut bar raised when tighting it back to the orginal nut position. I also left the rubber cushions in the hood for vibration dampening. I also installed an engine dampener for the hell of it. Keeps that engine in check! The hood sits nice and flush
Here are some pics as promised...
Zquicksilver
Old Apr 19, 2005 | 11:23 AM
Road Warrior
hey zquicksilver.....what is brand x....and can you give more info on that engine damper, such as does it decrease wheel hop at all?
thanks and glad all went well....i ended up with the same combo on my strut bar as far as the washers go
laterz
Old Apr 19, 2005 | 12:30 PM
  #38
Zquicksilver
Hey Road Warrior,
It's an engine dampener...it keeps the engine from torquing so much when you punch the gas. I thought it would help with possible vibration from the strut bar, you know, with the clearance of the strut bar issue? I simply attached it to the strut bar bolt and (timming belt casing) at the front most corner of the engine. I had to buy some new hardware to get it to work, but it wasn't a big deal at all. The actual dampener itself is the same thing Stillen offers, minus the hardware kit for install. Guess that's why Stillens costs over 2 times more...? It pays to be handy Anyway, imo Stillens dampener comes from China as does the one I purchsed on EBAY. If you look really close you can see they are the exact same product (ie just the dampener).
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7961393192
For $50 I thought it was worth it!
Zquicksilver
ps shifting is now much more precise...
Old Apr 19, 2005 | 01:57 PM
  #39
jkoc's Avatar
jkoc
zquicksilver
thanks a LOT for the really useful pics of your bolts.
freaking awesome. i had major leak issues with my installation -- in particular, bolt 2 and 1. i think the washers with the rubber base will help a lot, without having to torque it way over spec.
Old Apr 19, 2005 | 03:00 PM
  #40
Road Warrior
zquicksilver....why did you change out the rubber washers with the others....did you encounter problems with leaking?
also, where did you buy them?
thanks....peace out
