** NEW INTAKE MANIFOLD ** long awaited, with pics
Old Apr 13, 2005 | 01:32 PM
  #161
DragonZ's Avatar
DragonZ
Am I lost...Did anyone find out about how much this would cost? I just need to set aside the money.
Old Apr 13, 2005 | 01:34 PM
  #162
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
800-900 stated in the first post.
Old Apr 13, 2005 | 01:53 PM
  #163
zachcrosen's Avatar
zachcrosen
I believe that was 700-800.
  #164
Brandon@Forged
Oops.
Old Apr 13, 2005 | 02:11 PM
  #165
Gators2001's Avatar
Gators2001
Some one is trying to make some money on the side ......
Old Apr 13, 2005 | 03:16 PM
  #166
lsdunique's Avatar
lsdunique
Zach if you are still interested, give me a PM about running a group buy
Old Apr 13, 2005 | 04:04 PM
  #167
35ounces's Avatar
35ounces
03 CS Track 6MT
How about the NA numbers and cover pics before any GB talk!
Old Apr 13, 2005 | 04:10 PM
  #168
zachcrosen's Avatar
zachcrosen
PM sent Robert.
I think 35ounces has a good point. I think that NA numbers and pix of the new cover will definitely help to raise interest in this. Anyway, let me know what you want to do and how you want to do it!!
Zach
Old Apr 13, 2005 | 04:41 PM
  #169
zillinois's Avatar
zillinois
Does the manifold retain the stock hookups for brake booster, PCV, evap, etc?
Old Apr 13, 2005 | 05:12 PM
  #170
SungNamZ's Avatar
SungNamZ
Yes! I literally removed the V4 and lower intake and installed new intake for dynoing and testing. While I have not connected stock hookups in this pic, I am sure you can see where they go. I don't believe Kinetix has relocated. I think they have also added an additional plugged hookup for individual use (i.e boost or NOS) if desired. Similar to what is on front passenger side of OEM Plenum. Hope the pic helps?
Old Apr 14, 2005 | 08:00 AM
  #171
Phatmitzu's Avatar
Phatmitzu
Originally Posted by projectmrod
quick noobish question.
how come the z's dyno graphs always dip around 5600-6000rpm?
Yeah, I've noticed that too. Anyone?
Old Apr 14, 2005 | 08:30 AM
  #172
THX723's Avatar
THX723
that is the result of the shape of the ignition timing table and it being at the edge of the knock feedback zone.
Old Apr 14, 2005 | 09:29 AM
  #173
IceY2K1Max's Avatar
IceY2K1Max
In NA applications that IM design probably isn't much of a concern, however for FI cars, I'd be asking HOW they equally distributed air to all the cylinders.
Even on NA factory manifolds of VQ30/VQ35s, Nissan always massaged the farthest intake runners plenum to accelerate air velocity to feed the cylinders runners farthest from the throttle-body. Such as on this VQ30 where you can see the throttle-body entrance on the lower RIGHT and how the plenum is "squished" down going to the lower LEFT:
Old Apr 14, 2005 | 09:30 AM
  #174
blubyu's Avatar
blubyu
Originally Posted by SungNamZ
That's next! The last major tune I had was in November 2004. The altitude here in Albuquerque does cause some unique A/F problems The washer in the FMU have already been downsized.
Will go back in and do some major stuff once I receive the finished product. The purpose was to just switch from V4 to the new intake and post numbers. While I am waiting, new plugs have been installed, 380 injectors installed and ECU re-flashed by TS for larger injectors. As soon as I receive the final product, will put it back up on the dyno, post numbers and pics.
only 380cc injectors? Must be running a pretty high base FP considering they would be maxed out at the power you are making right now if the base FP was kept stock. Good luck with it all, cams would put you over the 400whp mark for sure. What size blower pulley are you running? Im assuming the one provided with the kit looking at your before numbers.
Matt
Old Apr 14, 2005 | 10:42 AM
  #175
sentry65's Avatar
sentry65
the burninator
how does this plenum sound in comparison to the normal kinetix one?
Old Apr 14, 2005 | 11:37 AM
  #176
002-M-P's Avatar
002-M-P
Is there any way we will be able to order one in the future with extra vacuum ports so we can run different accessories off different ports (i.e. boost controller, boost gauge, blow-off valve, etc)???
Old Apr 14, 2005 | 11:56 AM
  #177
lsdunique's Avatar
lsdunique
yes, in the future you will be able to add extra ports.
It will currently come with 1 extra 1/8" npt port already for gauges, etc.
Old Apr 14, 2005 | 12:00 PM
  #178
projectmrod's Avatar
projectmrod
so basically that means... that....
Old Apr 14, 2005 | 06:41 PM
  #179
valdeztke's Avatar
valdeztke
whatever happened to this?
Old Apr 15, 2005 | 03:21 AM
  #180
zachcrosen's Avatar
zachcrosen
There should be NA numbers by around Wed of next week as well as pix of the production polished IM and pix of the new engine cover. I am talking with ISD (Robert) about details of the GB on this IM as well as several other products from Kinetix. Keep an eye out here and in the GB forums about a GB for several of Kinetix's products!!
Zach
